Hello guys, one of my ssd's are almost full of memory and i have no clue what it is...
i got no games at all, no steam, origin, uplay, NOTHING and no movies either.
so can some of you come with a tip how or where to find the things that is eating up my memory, it much be much appreciated!
https://linustechtips.com/topic/169787-too-much-memory-need-a-hand/
C://
Uh. Maybe run CCleaner?
This. It will help a lot.
Are you absolutely sure you don't have any music or something on the drive? If not, CCleaner will do wonders on your computer. :)
try formatting the SSD and run CCleaner as others have said
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
paging file ?
hybernation file ?
I'm confused. Are you talking about storage space on SSD or RAM usage? The  troubleshooting is really different between these. As SSD it might be pagefile or some temp file. RAM might be some program having memory leak, virus or some weird background process.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
