Cables, know-how, what-do and what-not
24 pin ATX motherboard connector connects to the motherboard, it is the largest connector (some motherboards only use a 20 pin)
8 pin EPS (also known as 4+4pin) goes at the top of your motherboard to power the CPU (some motherboards only need a single 4 pin)
6 pin and/or 6+2 pin PCI-E power goes directly to your graphics cards to power them
molex is used to power fans, old drives, or other small things in your case.
sata is the replacement for molex (power supplies come with both molex and sata cables) which is now used for all kinds of drives.
Sleeving requires a lot of work to put a braided shroud over each individual cable to make it look better, and you also have to solder the connectors, use heat shrink, and crimp the pins.
It is much easier and safer to buy some pre-sleeved cable extensions from someone like bitfenix or silverstone or NZXT or corsair
If you sleeve your own cables there is a possibility you put one cable int he wrong place and fry all your components.
