Will these parts do for a CPU and 2 GPU's ?
Go to solution Solved by Izaya Orihara,
Yes.
RayStorm Twin D5 AX360 WaterCooling Kit a aqua link pipe and an extra 140mm rad with extra compression fittings, and tubing
It may be tight and temps may get quite warm, usually the minimum "recommendation" is 120mm per component, but having more is always better.
I'd recommend seeing if you can find a cheap 240mm or even a used one off ebay to add to the loop, just to make sure everything is nice and quiet whilst remaining nice and cool.
The 360 Rad should be okay, just dont expect crazy low cool temps, but acceptable considering and better than air....can you add in a 120 or 140 Rad plus the 360 anywhere?
3930K - 4.85Ghz w EK Supremacy | RIVE w Photon 170 D5 Vario / Res Combo | 16GB 1866 Doms | Evga GTX 780Ti SC SLi w EK Full WB's| AX 1.2 kW | 900D - 1 x RX480 1 x EX360 & 1 x EX240 Rads w Noctua NF F & Corsair SP "Push" | W7 HP x64 | MK11: P25,113 http://www.3dmark.com/3dm11/7499603 | Firestrike: 19,576 http://www.3dmark.com/fs/1177627
do you water cool your gtx 780's
Yes SLi 780tI's and CPU on the Loop.
