Fittings for soft copper?
Will regular fittings work for this? I need 3/8 OD fitting for soft coper tubing.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
thats what i thought, but in the frozencpu video with their soft coper tubing they used rigid acrillic fitings. And thoes dont come in 3/8 OD
Um, not really. Best going to a specialist fitting shop, and getting the correct "olive" fittings.  They are compression fittings for soft metals. And you will have to do them up pretty tight. So be cafe full with your other bits.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
That sounds expensive... and hard to find
cant you just use acrylic fittings for soft copper?
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
I couldent find any on frozencpu with 3/8 OD. But i found some up above as i marked best answer
so they do work? because im gonna use them for my next build... would suck to have 100€ of fittings that you cant use.
Fitting for rigid acrillc will work with soft copper, if the OD is the same.
Not really, in both ways, $2-5 a fitting, bout the same a standard compression fittings.
I see you found your answer. Sorry, I was drooling over in the build logs.. :unsure:
The ones i found specificaly for water cooling with soft coper are 9$/fitting
Wow, hope you don't need too many. Tha'ts exactly what I was trying to explain you could buy at the fitting shop. only difference would have been that they would have been brass fittings, not chrome ones.
Thanks for link above too. Very handy to have links to odd bits and pieces...
