hey guys so long story short my uncle got a gtx 590 and i took it of his hands
so i have 2 questions to ask
one:
do you guys think its go on a 2560x1080 resolution even though it only has 1.5gb per gpu im planning on getting one soon
second:
is there a way i can optimize the card to make it run faster, it is not reccomened to run it oced on a stock cooler, i tried to find a water block but its impossible to find right now.
sorry for my bad grammar and spelling as well :P
https://linustechtips.com/topic/166185-gtx-590-help/
1. yes
2. BULL SHIT. you can OC on anything the only difference the 590 will have is temperatures because its a duel gpu card
Specs
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211682
1. yes
You cannot OC the 590, it's VRM's will blow.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211685
1. yes
So do the GPU's duel to the death or something? Never heard of a duel GPU card before...
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211688
1. yes
yes though i am very scared due to people saying they have burned out the card buy doing so
also i can only get around 620mhz without bumping up the voltage
also thanks for the fast reply
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211689
You will blow the circuitry overclocking the 590 on standard air.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211693
i have heard of bad things happening with the card i guess he can slightly boost the card
where have you been for the last 10 years?
like i said above i guess you could slight change the clocks but honestly gpu OCs are like cpus OCs they do very little in my opinion
Specs
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211699
I have a 7990.... I know what a Dual GPU card. No idea what a duel GPU card is.
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211749
typo.... -_-
Specs
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211757
Le Bastardo+
Red Alert
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2211759
I still have my 590 here, and many many times I also asked for help and tried by myself overclocking the card, but it just doesn't overclock...you add 20Mhz and you've got yourself a bunch of artifacts and unstable performance. I wouldn't overclock it unless you have a waterblock and know how to flash the bios to overvoltage it. But even then, you'll get at max ~700Mhz (stock is 608)
do you by any chance where i can get a waterblock?
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2215812
Well.. I have a 580 and only recently upgraded. I noticed my vRAM was at 1.4GB'ish+ for the games I played. That's on one single 1080p monitor, settings not maxed out. I don't think you can but I do think you can max out a single 1080p panel. The lack of vRAM will make you want to shoot yourself as you wont be able to make use of the power underneath the hood.
Might be a good idea to invest in some earplugs... :D.
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2216621
so far i love my 590 with my 1080p monitor but i would like to go 21:9 and ik even on 1080p i wanna commit suicide with that vram, i do get to downscale a few games such as lol and most source engine games on 1440p. but hey what can say when you get a card like that for free :P also linus showed a demo of 3x 1280x720p in surround which looks more demanding then a 21:9 for the 590
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2217303
If you really need more performance, take your chances and sell the card, and invest on a 780ti. People, and even Linus, said that it wasn't much of an upgraded, but I call BS. It's still a nice card, but going to a 780 Ti gained me almost, sometimes even more, 50% improvement. Heaven 4.0 Ultra detail, Extreme tesselation 1080p = - 590 = 45 fps   - 780 Ti = 68 fps
Edit: correction
gtx 590 is much slower than the 780 ti on air but it gets quite close after water cooling it (i think :P) which i was planning on doing if i could find one but if i cant how much do the 590's sell for nowadays?
https://linustechtips.com/topic/166185-gtx-590-help/#findComment-2221953
