C# HELP
Go to solution Solved by WanderingFool,
You have two choices, well you do have more, but there are two more common choices.  Pass the col/row size through parameters, or make them class variables (which I think in this case would make sense).
I chopped it up a bit just to show you how it is done.
Class variable
namespace Pereyra_HW2{    class Pereyra_HW2    {        int colSize = 0; //Now this will be accessible for anything in this class        int rowSize = 0;        static void Main(string[] args)        {            Console.WriteLine("\t\t\t   Magic Square Simulator\n");            do            {...rest of code as is
Parameter
        static void Main(string[] args)        {            int colSize = 0;            int rowSize = 0;            Console.WriteLine("\t\t\t   Magic Square Simulator\n");            do            {                Console.Write("Enter your Magic Square column size(e.g. 5): ");                colSize = int.Parse(Console.ReadLine());                if (colSize > 9)                    Console.WriteLine("SYSTEM OVERLOAD ERROR! Cannot Process more than 9");                else if (colSize < 0)                    Console.WriteLine("SYSTEM UNDERLOAD ERROR! Cannot Process less than 1");                else if (colSize == 2 || size == 4 || size == 6 || size == 8)                    Console.WriteLine("SYSTEM ERROR! Odd numbers only");            } while (colSize != 3 && colSize != 5 && colSize != 7 && colSize != 9);            GetMagic(colSize, rowSize); //Calling it using parameters        }        public static int GetMagic(int colSize, int rowSize)        {            int[,] grid = new int [colSize, rowSize]        }
Also for odd numbers
int i = 9;if(i%2 == 0) //Evenif(i%2 == 1) //Odd
Basically % is the remainder if you were to divide.
Hi guys!
So I have this code in C#:
using System;using System.Collections.Generic;using System.Linq;using System.Text;namespace Pereyra_HW2{    class Pereyra_HW2    {        static void Main(string[] args)        {            int colSize = 0;            int rowSize = 0;            Console.WriteLine("\t\t\t   Magic Square Simulator\n");            do            {                Console.Write("Enter your Magic Square column size(e.g. 5): ");                colSize = int.Parse(Console.ReadLine());                if (colSize > 9)                    Console.WriteLine("SYSTEM OVERLOAD ERROR! Cannot Process more than 9");                else if (colSize < 0)                    Console.WriteLine("SYSTEM UNDERLOAD ERROR! Cannot Process less than 1");                else if (colSize == 2 || size == 4 || size == 6 || size == 8)                    Console.WriteLine("SYSTEM ERROR! Odd numbers only");            } while (colSize != 3 && colSize != 5 && colSize != 7 && colSize != 9);        }        public static int GetMagic()        {            int[,] grid = new int [colSize, rowSize]        }    }}
And I want to know how I can get the "colSize" and "rowSize" to link also to the function "GetMagic".
And also, any help on the syntax on how to make/compute for an odd numbered magic square would be nice. Thanks! :D
CPU: Intel Core i5-4670k Mobo: MSI Z97 Gaming 3 RAM: Crucial Ballistix Tactical Tracer 8GB 1866 Video Card: MSI GTX 970 GAMING 4G SSDSamsung 840 Evo 250GB HDD: WD 1TB + 500GB Caviar Blue
PSU: EVGA SuperNOVA 750W G2 Case: Gigabyte GZ-G1 Mouse: Corsair M65 RGB Keyboard: Corsair K70 MX Brown MousePad: Corsair MM200
Steam/Origin/Uplay: renz62
https://linustechtips.com/topic/166173-c-help/
Hi guys!
What exactly do you want to achieve? I dont understand what you wrote.
You want the getMagic() function to print out the square of a given size?
https://linustechtips.com/topic/166173-c-help/#findComment-2211550
yes.. that's it!
Then i'll just return the results of getMagic() to the main function
https://linustechtips.com/topic/166173-c-help/#findComment-2211565
Class variable
Parameter
0b10111010 10101101 11110000 00001101
https://linustechtips.com/topic/166173-c-help/#findComment-2213051
-snip-
Thank you very much for the help!! :D
https://linustechtips.com/topic/166173-c-help/#findComment-2216236
