Hey i have attached a question i am stuck with. The 1st part i can do and kind of the 2nd but the 3rd part just confuses me too much.I dont know where to make a start A=1 B=19
I dont normally ask for help in maths but this one i just cant not do been stuck on it for too long and is driving me mad :(  .Thank you
https://linustechtips.com/topic/165891-help-with-maths-a-level/
well do you have a graphic calculator? maybe a TI-86?
try wolframalpha. super easy to use
http://www.wolframalpha.com/input/?i=graph+acos%28t%29
yes I already have solved it but I am not going to give you the answer.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2207908
Wolframalpha is your friend!
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2207911
Yerr helping but not a lot. I will try some more
I would like to help you but I have no fucking idea what a wave is.
I've just finished the 8th grade and I couldn't know that.
I helped as much as I could :D
Good luck.
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2208005
I do not understand this type of equation, i only understand the day and month thing before it :P
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2208013
For part B you wanna use wolfram alpha, and for part c.
R is equal to the square root of a^2 a b^2
and the angle is inverse tan b/a.
Im guessing this is a C3 question if you wanna look at a mark scheme its similar to question 8 in this paper, but its just an algebraic version, and more theoretical. Paper
The mark scheme is here
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2208028
See now i like Algebra, but the OP question is not Algebra to me, or at least i don't think lol.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2208042
It seems like you'd just draw a sin and a cos graph on the same graph, with the 'amplitude' of the lines being +- the day or the month respectively.
Then you need to add some waves which isn't on the A-Level side of things, at least not in C4, so you'll have to carry on from there
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2208589
http://www.wolframalpha.com/input/?i=graph+acos(t)
Btw that's the graph of arc cosine lol. You clearly didn't check it/read the question :P
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/165891-help-with-maths-a-level/#findComment-2208900
