hi there i'm planing my first build and need some help and advice i'm currently using a Toshiba satellite laptop as my gaming rig but i'm looking to build my first desktop. I'm aiming for a budget of $1500 Australian dollars it needs  to be small to fit on my desk as why I've chosen a micro atx case and motherboard the specs will be below i do mostly gaming and light video editing.
thanks to everyone that helps woodsyjr1555.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler
Motherboard: Gigabyte GA-H87M-D3H Micro ATX LGA1150 Motherboard
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Sandisk 128GB 2.5" Solid State Drive
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Asus GeForce GTX 760 2GB DirectCU II Video Card
Case: BitFenix Phenom M Midnight Black MicroATX Mini Tower Case
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified Semi-Modular ATX Power Supply
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)
Wireless Network Adapter: TP-Link TL-WN951N 802.11b/g/n PCI Wi-Fi Adapter
Case Fan: BitFenix Spectre LED 43.5 CFM 120mm Fan
Case Fan: BitFenix Spectre Pro LED 56.2 CFM 120mm Fan
Total: $1516.99
https://linustechtips.com/topic/165758-i-need-advice-first-build/
better use the quote button if you want my help
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($285.00 @ PLE Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard: MSI Z97I Gaming AC Mini ITX LGA1150 Motherboard  ($249.00 @ PCCaseGear)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($99.00 @ Mwave Australia)
Storage: Corsair Force LX Series 128GB 2.5" Solid State Drive  ($99.00 @ CPL Online)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ CPL Online)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  ($369.00 @ Mwave Australia)
Case: BitFenix Prodigy (White) Mini ITX Tower Case  ($85.00 @ CPL Online)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer  ($22.00 @ Mwave Australia)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ CPL Online)
Total: $1539.00
Generated by PCPartPicker 2014-06-13 22:17 EST+1000
Specs
Storage: Corsair Force LX Series 128GB 2.5" Solid State Drive  ($99.00 @ PCCaseGear)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  ($369.00 @ CPL Online)
Total: $1402.00
Generated by PCPartPicker 2014-06-13 22:12 EST+1000
Get this one
you must REALLY want to go MINI ITX to pay 249$ for that motherboard...WTF?
a micro ATX motherboard would be much better?!...also MUCH cheaper...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
My advice would be a bigger desk instead of overpaying that much to make a small form factor build, as a desk would probably cost less. But then again I dont understand small form factor's unless you need to cart it around to LAN parties and what not. Also you should get z97 for the future proofing.
Dubs are better than subs
