Corsair's Air 240 looked pretty nice at Computex, their 350D is another great option. Fractal Design's Arc Mini R2 is nice as well as their Define Mini. All should support water cooling quite well. A basic/budget option would be something like a Rosewill Line-M.
I should be studying.
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199264
350D
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199268
Corsair 350, a Bitfenix Prodigy is also nice but it'll take some modding and careful planning to watercool.
I thought the micro ATX version of the Prodigy doesn't support water cooling all that much past an AIO. I think the Mini Itx version is much more suited for water cooling. I'm not sure though.
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199281
Arc R2 Mini?
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199308
Corsair's Air 240 looked pretty nice at Computex, their 350D is another great option. Fractal Design's Arc Mini R2 is nice as well as their R4 mini. All should support water cooling quite well. A basic/budget option would be something like a Rosewill Line-M.
R4 mini is an awesome mATX case.
It's not a R4 mini, it is the Define Mini, no Rs no 4s, just Define Mini.
Define Mini definitely not good for water cooling, If you want mATX Fractal and water cooling then you want the Arc Mini R2.
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199314
I meant Arc Mini R2 :/ Damn you Fractal and your categorization!
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199329
Arc Mini R2 is pretty good, but the corsair air cube 240 seems that it would have better rad support, considering the 540 had pretty good rad support
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8 | Panasonic 14mm F2.5
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199361
You're absolutely right. A little oversight on my part, forgetting the mATX criteria :P. IMO the mITX Prodigy makes for a cleaner build tho.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199362
Mercury S5 if you want to be a baller
Arc Mini R2 is another great option
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/165264-best-matx-case/#findComment-2199584
