Im wanting to buy a new motherboard and a capture card. the mother board i want is the ASUS M5A99FX PRO R2.0
im going to be running two GTX 650 Ti Boost GPU's but i also want to put in a AVerMedia Live Gamer HD card. is it possible to fit a
smaller port card into an x16 slot. due to the fact the only slot it can naturally fit in is covered by the first GPU.
https://linustechtips.com/topic/165239-pci-e-questions/
Yes, it is possible.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/165239-pci-e-questions/#findComment-2198996
yeah iirc all PCIE slots are compatible :P you just won't be able use the locking mechanism and well bandwidth limitations are still present (eg a 4x card in a 16x slot still is only as fast as a 4x slot)
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/165239-pci-e-questions/#findComment-2199068
