I have an AMD athlon 760k and when I'm browsing the internet hardware monitor and NZXT CAM both tell me I have a temperature of 70 degrees and it sometimes even peaks at 86 degrees. I have a coolermaster seidon 120V. I'm thinking I must have installed it wrongly or the thermal compound needs re doing and the cooler remounted. Any ideas?
Cheers in advance.
https://linustechtips.com/topic/164420-cpu-temperature-seems-too-high/
Yeah, it could be that the cooler just didn't seat properly.
I'd advise taking it off, cleaning off the thermal paste, re-applying thermal paste then remounting the cooler.
They run pretty hot so  its possible that's probably quite normal
if not try reseat it with some new thermal paste
