I need help
Go to solution Solved by Nxl8,
i hope its just a ram issue, though the results i got from the whocrashed program concerns me too.
Something else to try would be to reset CMOS. You will lose all BIOS settings including any overclocks. There are various ways to do this. If you search up how to clear CMOS jumper there will be thousands of tutorials online, searching those up would be far easier than to explain.
Okay i have a problem with my PC, ever since i accidentally knocked it over it started acting real slow. games would be really choppy and videos would frame skip then after a while it blue screened. I tried to see what the problem was but no luck, i swapped out hard drives thinking it was probably damaged but while i was installing the OS on the new drive it blue screened. strangely though i can still access my desktop, it boots up all the way but eventually bluescreens, and after i backed up my data again it blue screen. when i restarted it it would just turn off till the next day it booted it up all the way so now i'm not sure what's wrong anymore, though my friends tell me it might be a cpu or motherboard problem. i forgot to mention that the bluescreen doesnt give me an error code.
my PC specs are
Msi Z87-G41 pc mate
Nvidia GTX 660
OS windows 8 pro
Intel i5 4670k
ram Corsair vengeance 8g
One terrabyte hard drive
https://linustechtips.com/topic/164193-i-need-help/
Is everything still seated nicely (video card and RAM in the slots firmly and locked in, CPU cooler mounted properly)?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/164193-i-need-help/#findComment-2184395
Whocrashed program to see what BSOD causes are.
Rebuild the computer pretty much. This makes sure all components are properly seated since a fall can make them come loose
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/164193-i-need-help/#findComment-2184398
Yes i opened it to check if anything came loose but everything was still firmly in place
Power cables/data cables as well?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/164193-i-need-help/#findComment-2184660
Yes they're hooked up good
In that case I'd do what @ttam said. Take it apart, rebuild it, clean it if it's dusty (you never know). and then use WhoCrashed (direct download link) to see what causes the crashes.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/164193-i-need-help/#findComment-2184950
okay so i did that then ran the whocrashed program and got two errors which were Kernel security check failures. on the descriptions one was a Ntoskrnl.exe and the other was afd.sys not to sure what those are and they had data corruption. i can post the screenshot if you guys would like.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2196290
so i did it, then ran whocrashed and gave me two errors. i'm not sure how to fix them, any advice?
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226000
Run Memtest if you haven't already, this might show an issue as if I remember rightly that kernel is to do with memory; RAM or HD could be cause.
Also run chkdsk /F in command prompt although you said you tried a different HD it doesn't hurt to check. It is more likely a RAM issue.
"Maybourne, you are an idiot every day of the week; why couldn't you have just taken one day off?!" —Samantha Carter
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226064
Run Memtest if you haven't already, this might show an issue as if I remember rightly that kernel is to do with memory; RAM or HDD could be cause.
Err I don't know why but when editing my last post it decided to quote it and make a new post for no reason. Sorry about that.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226119
It did it again...
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226134
Where do you get memtest?
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226189
okay i got the usb one, and installed it on a pindrive since i dont have a floppy or a cd to burn. how do you use this?
http://www.geekstogo.com/forum/topic/246994-guide-to-using-memtest86/ this guide should be good enough. The first bit is about downloading and burning, it sounds like you have done that part though.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226345
okay, so i was able to run it but strangely when i was checking the ram the PC just shut off, so at first i thought nothing of it then swapped out the stick ran it again and it also shut off. not sure what that means.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226568
CCould possibly a RAM issue but I am not terribly experienced in these issue so you may wish to ask someone else or try googling possible reasons why.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226623
https://linustechtips.com/topic/164193-i-need-help/#findComment-2226905
Okay i've been busy this week but i came back, reset the bios and turned it back on it went to the desktop like usual and it ran videos fine for a while so i decided to run a defrag for the drivers and normally when i did that it would blue screen. this time however it made it to ten percent then it just turned off, not sure what caused that.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2264719
it looks like reseting the bios fixed it after all thank you so much bro, at first i thought it was still broken cause it shut off on its own and after i messed with the powersupply switch, flicking it down then back to its original spot. when i turned it on the day after it ran super smooth and when i ran my games they were perfect so were my videos. thank you!
https://linustechtips.com/topic/164193-i-need-help/#findComment-2270803
Glad I could be of help.
https://linustechtips.com/topic/164193-i-need-help/#findComment-2271193
