TEC (Peltier) cooling
Eh, it's a lot more trouble than it's worth honestly.
Probably not. A fan isn't going to stop water from condensing on the plate. It will push water in a direction, but it will have to form first. You should coat the motherboard in Plasti-dip. That way, any condensation that forms won't be able to affect a thing, however this will impact your cooling ability somewhat.
.... No. I would imagine it cannot cool 400w of heat. 400w is a lot. Most CPUs TDP is 125-200 maximum (and that's pushing it). Overclocking might add like 50w, but nothing near 400w. I seriously doubt it'd be able to keep up personally.
If you wire it correctly, yes you can use your PSU to power the peltier cooler. The problem is that it will use as much energy as the CPU does to pump the heat away, so it isn't energy efficient at all.
You have to add both the inefficiency of the Peltier cooler and the TDP of the CPU together to find out how much cooling potential you need. Otherwise, you won't be doing much.
I would only go with the Swiftech loop and forgo peltier cooling altogether. It's simply not worth it.
Dual pumps are only necessary for redundancy. I'm pretty sure any decent pump like the H20 can keep a good flow going in that kind of loop.
I come here saying all this because I asked a similar question and got a similar answer to what I've given here. It's possible, but certainly not worth it unless you just want to be that guy with that sub-ambient CPU temp (i.e. an enthusiast who doesn't care about practicality at all, which is fine. I'm that type of guy too, but I just don't like maximal effort for minimal reward type things, which is what I define peltier cooling as).
