I'll assume it's for 1080P Gaming/editing. So imo you're good to go! :)
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182494
you could save yourself some money on the psu, unless you plan on going sli in the future. this system wont consume more than 450W, so anything from 500W up would be fine.
other than that, solid choice, great build
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182506
Are you planning to sli?
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182549
No I'm not. not in this build at least.
If you don't use the quote button it will be harder for the guys you're talking with to know that you said something, if you use it they will get a notification.  ;)
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182581
This is my new PC I'm building and would like some opinions on the hardware. This rig will be for Heavy gaming, serious MS word work (yes, you can tax hardware with MS word) and light video editing for YouTube gameplays. http://pcpartpicker.com/p/LwTJmG
looks really good OP.  If your just building this now. Z97 is the chipset you should get now.   It will help you benefit later on for around the same price
Z97 versions of your choice in 2 SKUs.
http://pcpartpicker.com/part/gigabyte-motherboard-gaz97xud3hbk
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182621
you will be good for the gaming but won't an I7 be better for the hyperthreading with video editing and ms word :P
and what video editing software are you gonna use ? try to find more nvidia based software then it will go much faster.
and like what other say get lower watt psu and instead silver maybe get gold ;)
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182772
The memory kit is not optimal with the Hyper 212 EVO. Consider instead http://pcpartpicker.com/part/kingston-memory-khx18c10k28 or http://pcpartpicker.com/part/a-data-memory-ax3u1600w4g9db. Depending on how big your Word documents are and how many images they contain, you might even consider 16GB. Presuming the budget permits.
The psu is much larger than needed. Something in the 550W - 650W is more than sufficient. http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm, http://pcpartpicker.com/part/corsair-power-supply-cs650m, http://pcpartpicker.com/part/corsair-power-supply-cmpsu650hx, or http://pcpartpicker.com/part/seasonic-power-supply-ssr650rm are all reasonable alternatives.
https://linustechtips.com/topic/164047-pc-build-opinions/#findComment-2182919
