I'm planning to buy a new phone and intend to keep it for at least 4 years.
My usage: I'm a light user, mostly social media, browsing, and occasional multitasking like Google Maps + Spotify + Instagram running simultaneously. I can tolerate minor slowdowns, lag, or stutters, but what I absolutely cannot deal with is the phone becoming completely unresponsive and hanging.
The two options I'm considering:
  • Samsung Galaxy M56 (Exynos 1480)
  • Motorola Edge 70 (Snapdragon 7 Gen 4)
Here's my dilemma:
Samsung promises OS updates up to Android 21, which sounds great on paper, but I'm not confident the Exynos 1480 is capable enough to handle later Android versions smoothly, especially since OneUI is already on the heavier side as far as Android skins go. On top of that, Samsung has a known green line issue with their displays, which makes me nervous about long-term reliability.
Motorola, on the other hand, only guarantees updates until Android 19. However, I'm fairly confident the Snapdragon 7 Gen 4 can handle Android 19 without breaking a sweat. That said, Motorola has had a pretty bad reputation lately, especially in India, their after-sales service and software update track record have been questionable. I recently came across a post claiming that an Android 16 update bricked the motherboards of some Motorola phones, which is honestly alarming.
So here I am, scared of both options for different reasons.
Any insights and advice would be hugely appreciated!
TL;DR: Choosing between Samsung Galaxy M56 (Exynos 1480) and Motorola Edge 70 (Snapdragon 7 Gen 4) for a 4-year keep. Samsung has better software support and UI but uncertain long-term performance and display issues. Motorola has a more capable chip for its update window but has a worrying reputation for after-sales service and buggy updates in India. Can't decide, need advice!
Yes, I have used AI but only for rephrasing my paragraph and giving it a better structure. Thank You.
