Budget (including currency): 1.7 Lacs / 1800 USD
Country: India
Games, programs or workloads that it will be used for:
Games like Forza Horizon 6, Horizon I & II, Wukong, upcoming Witcher 4, Assassins creed, Marvel Rivals. (Majority workload - 4K/60 for cinematic AAA, 1440p high-refresh for competitive)
Workloads involve CAD modelling (Fusion and SOLIDOWRKS mostly), ANSYS (light work and occasional) and Blender 3D  (Bit heavy on rendering but also occasional).
Bit of ROS-related work & software dev as well, but planning to dual boot with Linux for that.
RAM - ZGJOLONG 8×2 DDR5-6000 C28 A-die (Hoping to upgrade & buy 2 more exact same sticks when prices go down)
SSD - Kioxia SF10 2TB NVMe (Owned) - 220 USD
CPU + Mobo - R7 7800X3D + Colorful B850M WiFi7
GPU - Vastarmor RX9070XT Starry Sky
PSU - Thermalright TR-SP850 Platinum
Monitor - AOC U27G4XM 4K 144Hz Mini LED (Owned) - 325 USD
Keyboard - Monsgeek Fun60 Max(Owned) - 30 USD
Mouse - VXE R1 Nearlink(Owned) - 12 USD
Case - CM Elite 481 Wood (Owned) - 55 USD
Cooler - Thermalright PA120 Digital ARGB(Owned) - 26.15 USD
Note :
- I do buy a lot of components from China (taobao/Tmall/physical store) where I go for work every few months. Majority of this rig has been designed considering Chinese companies, vendors and current pricing. Headed to China in May first week, and aiming to buy all the pending stuff then.
NEW to this forum as well by the way, open to  any and all advice and recommendations.
https://linustechtips.com/topic/1635205-first-pc-build-reccommendations/
- Yeah, current prices for 1X16 GB stick is more than 2X8, which are already high enough. Would it be fine to just buy single 16GB stick and buy another later ? Would single channel vs. dual channel make a big difference in performance for games ?
- Also 9070XT is a bit pricey for my budget. Would 7900XT or 9070 be good enough ? Those two are cheaper than 9070XT.
I'd personally grab 1x16GB DDR5 vs 2x8GB.  Add another 16GB stick later, for 32.
With DDR5, you don't lose much going 1 stick as that single stick can be dual channel by itself if what I read is true...
Single Stick vs. Dual Channel RAM: How Much Performance Do You Actually Lose? | TechSpot
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
9070 will work fine.
I'm not sure single stick can be dual channel, what it can be is dual rank.
Which aren't same things:
current PC:
PC configs I used before:
I am planning to buy a single 16GB stick for now, and get another one later ones prices drop. But I can't guarantee I will get the exact same RAM stick later. If I get another stick which is a different die (M-die, A-die etc.) or a different CL timings values like C28/C30/c32 etc, how much of an impact would that make on my system ?
how much performance loss will you experience heavily depends on what games will you be playing also .
for example 9700x is loosing 35% of its performance in marvel rivals , but in some other games it´s just 5% (but that´s with rtx 5090) .
lucky for you X3D chips are less sensitive to single stick vs dual channel due to massive cache compared to regular CPUs
- so you should be totally fine with a single stick for now .
ideally you should try to find the stick with the same specs from the same manufacturer .
but even if you don´t there is still a pretty good chance it will work in dual channel
the faster memory module of the two should adjust and sync its speed and timings with the slower stick -
(or they both work at default DDR5 speed)
usually it either works from the get go or it doesn´t work at all ...
after you verify that the dual channel is working at synced default speeds
you can go from there and try to set EXPO profile and see if it works .
i7 8700K , Z370 K6 FATAL1TY , GTX 1080Ti rog strix , NOCTUA NH-D15S ,
2x16gb DDR4 3200MHz/cl16 , FRACTAL R5 window , EVGA G3 750w gold ,
480gb m.2 NVMe WD SN350 + 500gb SAMSUNG EVO 850 ,
creative sound blasterX AE-5 Plus , MSI Optix G241 , WINDOWS 10 PRO
