Remote for PC?
Solved by Needfuldoer,
6 minutes ago, Mark Kaine said:Hmm I don't need to turn on off the pc with it, just control YouTube, switch tabs, open close windows etc...
Basically something like this should work?
We have a bunch of those at work. (At least, that same controller under a different brand.)
They're okay, but kind of shaky. The old Wii controller had better tracking, since they had the "sensor bar" for their cameras to watch.
