Help with new PC build.
Go to solution Solved by P e r s e p h o n e,
The PC will mostly be used for gaming and a little bit of powerpoint and excel use. The budget for the build is from 500 to 600$. Since I'm limited to only some parts for a new PC, because I ordering the parts from amazon.co.uk will be just too expensive. As for the looks of the PC it really doesn't matter, all black will do nicely. I will most likely upgrade some parts later on, but for now this is just a budget PC. I've made some changes to the partslist, is it any good now? http://pcpartpicker.com/user/AurisxD/saved/FRndnQ
I think this is a pretty good build. If you can find similar pricing of Cacao's listed budget build there in the U.K. that would be better.
Hello everyone, I would like to get some advice about my first PC build. I've already picked every single part for the PC and I would like to know if everything is okay, are the parts compatible with each other.
http://pcpartpicker.com/user/AurisxD/saved/cxTPxr
This is going to be my first time build a PC, but I watched a couple of build guides and I think it shouldn't be that hard.
Thanks in advance.
https://linustechtips.com/topic/162523-help-with-new-pc-build/
The CPU Choice was one I went with as well with my build at first until I took a look at the FX-6300 which benchmarks allot better than the Athlon.
Main Machine:  16 inch MacBook Pro (2021), Apple M1 Pro (10 CPU, 16 GPU Core), 512GB SDD, 16GB RAM
Gaming Machine:  Acer Nitro 5, Core i7 10750H, RTX 3060 (L) 6GB, 1TB SSD (Boot), 2TB SSD (Storage), 32GB DDR4 RAM
Other Tech: iPhone 15 Pro Max, Series 6 Apple Watch (LTE), AirPods Max, PS4, Nintendo Switch, PS3, Xbox 360
Network Gear:  TP Link Gigabit 24 Port Switch, TP-Link Deco M4 Mesh Wi-Fi, M1 MacMini File & Media Server with 8TB of RAID 1 Storage
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163406
I'd always ask a person if they asked themselves what the purpose of their build is, their budget, and if there are any circumstances such as upgradability and form factor. Knowing that have you thought about things of that nature? Although less important; do you care about the look of your build? Another piece of advice I'd always iterate is does it make sense for you to save a bit more and spend a bit more later. Sometimes depending on the price point of your build it is optimal to save a bit more for that performance gain. In the end the price to performance is what makes the difference and sometimes by waiting just a bit and spending a little more you get a better price to performance ratio. That last advice is advocated by Linus himself.
You gotta do you girl. I always say you gotta do you. And if he's doing him, then who's doing you? Because right now, it seems like no one's doing you.
- Stefani Stilton (she / her) 🏳️‍🌈🏳️‍⚧️
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163456
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i3-4150 3.5GHz Dual-Core Processor  ($118.48 @ SuperBiiz)
Motherboard:  MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.99 @ Newegg)
Memory:  Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Amazon)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.43 @ OutletPC)
Video Card:  Sapphire Radeon R7 260X 2GB Video Card  ($115.38 @ Newegg)
Case:  Rosewill REDBONE U3 ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply:  Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Newegg)
Total: $457.25
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-06 06:18 EDT-0400)
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163461
Take a look at this, it's quite a bit better:
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163496
I'd just put a 270x in there and you'd have something near perfect.
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163507
is that your video? i made similar build up there. could even add better gpu.
Yeah that's my video, parts list perfected by LTT :P We thought long and hard.
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163517
I know with the price point listed you get quite the competition to consoles however don't you think the extra price to performance ratio would have been worth it with the r9 270x?
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163536
Right now it is!
CPU:  Intel Core i3-4130 3.4GHz Dual-Core Processor  ($114.50 @ Amazon)
Memory:  Patriot Viper 3 8GB (1 x 8GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Video Card:  PowerColor Radeon R9 270X 2GB TurboDuo Video Card  ($154.99 @ NCIX US)
Case:  Zalman ZM-T1 MicroATX Mini Tower Case  ($32.99 @ Mwave)
Power Supply:  Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Micro Center)
Total: $500.88
(Generated by PCPartPicker 2014-06-06 06:40 EDT-0400)
When I originally made the video, the total was like 510$ or something, now you can fit a 270x in 500$.
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163549
Right now it is!
Total: $500.88
Holy crap. That's dirt cheap for something that powerful. You should make certain options available for different form factors if you can. Also somewhere towards the end of the video tell people to splurge a little here and there to get a cool looking rig custom to your taste. Personally I'd spend an extra 50 dollars just to have an awesome case. I feel like that would make it more attractive to a prospector. I don't know why but I was wondering whether or not to like this for its awesomeness then I saw your title and was like awww.
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163565
Yeah I added a few extras at the end, including a case ;)
You can get some pretty badass hardware for very little money nowadays.
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2163579
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2166461
https://linustechtips.com/topic/162523-help-with-new-pc-build/#findComment-2167920
