Unreal engine 5 games issue
Go to solution Solved by Ebony Falcon,
If u want silent hill f to run well
Set frame cap front edge sync and 160fps in rtss
drop lumen settings from epic to high
Smooth motion on in the nvdia app ( it’s more than good enough at 160 fps)
And dlss quality if needed to keep gpu usage under 90 percent ( u want a decent gpu usage buffer when capping frames )
game will run at a locked 160 average with 0.1 lows going to 148
just reading ur post if u don’t restart the pc u said u have windows open in background from work ect
obviously they get closed when you restart the pc so Maby try just closing those windows and programs and only having the game running
also the programmes ur using for work are probly leaving background processes running which Definatly won’t help
My new rig is a 9800x3d and 5070ti with 32 gb ram. Currently playing kingdom come deliverance 2, battlefiled 2042, silent hill f and borderlands 4. I use the pc for work usually having quite a few windows open and in the evening for gaming. I find that for borderland 4 and silent hill f, restarting the pc every few days makes the games run smoother. I do not need to do this with the other 2 games, I can never restart and they run fine. Has anyone else experienced this? Is this because of bad optimisation of unreal 5 engine games?
https://linustechtips.com/topic/1624314-unreal-engine-5-games-issue/
Yes, and yes.
It's covered in the Borderlands 4 fix thread.  As well as many many many other gaming news websites that break it down pretty well, as Epic has chimed in even.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Sadly nothing new, slop coded games releasing.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
-14900kf
- 4000 32gb ram
-4070ti super duper
Smooth motion made such a big difference, thanks again
No worries man, I enjoy taking games that “run bad” and finding out how to make them run better and more enjoyable
not sure if I like doing that more than playing the actual games lol
I’m about half way through silent hill f I’m really enjoying it
Justin case you don’t no how to set up the frame limiter, download msi afterburner, install it and the other program it comes with called rtss
open afterburner and minimise it, go to system tray and u will see a program that looks like a little blue screen,
click and open that, ul see a box to type a number to limit frames type the 160 in there then click on the settings option at the bottom and find the option called async click that box and it will show more options, in there you can choose front edge sync
-14900kf
- 4000 32gb ram
-4070ti super duper
Thanks m8 but the smooth motion not only fixed silent hill but also borderlands 4, they are running really well. It looks like this is a must for unreal engine 5 games.
You don’t need it in borderlands, that one has built in frame gen and is better than smooth motion
-14900kf
- 4000 32gb ram
-4070ti super duper
