HI all,
I'm wanting some help with my storage system I have 6TB of HDDs in my computer and want to upgrade them to M.2s, iv done some googling and turns out you need to have bifurcation on you motherboard to be able to use an expatiation card using PCIE but my motherboard doesn't have this, can you get PCIE cards that have bifurcation on board and are there any cheap option im looking to spend around £150 mark if needed but less would be better.
https://linustechtips.com/topic/1623546-need-help-with-my-storage-set-up/
Yes. They use a PCIe switch to route to multiple M.2 slots. The two slot version can be reasonably priced, but the four/eight slot ones can get expensive. Also, they tend to be generic Chinese designs with little-to-no end-user support. (I have one; they do work, FWIW.)
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
30 minutes ago, Electronics Wizardy said:
Full system specs?
What drives do you want to use? Why not get a single 8TB SSD here instead of multiple drives?
I9-12900K
96GB RAM
GTX 4070
corsair 1000W
Samsung 970 Evo 1TB main drive, 870 QVO 2TB,
Seagate 2TB, 3TB, 4TB,
Crucial 2TB, 4TB
870 QVO is currently in a PCIE card which is when i found out that i couldnt have multiple drive as i got 3 drives off an auction site for cheap (have checked to make sure all works) I have two other M.2 Drives to put in
I would like to grab a 4 slot card, would you have any recommendations for one ?
2 minutes ago, Wolf19115 said:
I9-12900K
96GB RAM
GTX 4070
corsair 1000W
Crucial 2TB, 4TB
Why is the 870 QVO in a PCIE card? Thats a SATA SSD, put that in a SATA bay so it doesn't use a PCIE slot.
Full system specs please. I don't see a board listed.
Your paying a good amount for a gen 4 switched card, your typically much better off just getting a single large 8TB drive here I'd guess.
Sorry got my drives mixed up the 870 is in a sata day, its my Crucial 2TB thats in a PCIE slot
The best solution I see here is replacing your smaller SSD with larger drives. You can get adapters with pcie switches, but those aren't cheap typically and fairly power hungry.  Or get SATA SSDs.
