First PC build and need help
5 hours ago, RockstarArthur said:Go for an AM5 build. Choose the Ryzen 5 7600 along with a RTX 5070. Also, add 32GB DDR5 CL30 6000MHZ RAM. These parts should easily let you game at 2k or even 4k for several years down the line.
Thank you so much for this info. I have been having the hardest time figuring out CPUs and obviously I am not doing well learning the other things ha ha.
7 hours ago, KodokuShelby said:Here's what I'm gonna recommend for ya.
The Ryzen 5 7600X is great, 6 Cores is a wonderful sweetspot nowadays, 105w tdp can be handled fine by the Hyper 212 (I have a 12700K with this thing, I know), and on AM5 with future upgrade potential!
RTX 5060 Ti 16GB because blender prefers Nvidia to AMD (according to a google search) and I wouldn't recommend buying the regular 5060 with 8GB cause it can be limiting in games now.
Crucial's 1TB SSD is the same price as their 500GB.
Not much I could cut on and keep the same performance (but don't just rely on my message)
Thank you so much for your reply and additional info. Idk why I wasn’t looking at AMD vs Nvidia when considering doing more Blender. I think your input is super helpful and will help point me in the right direction.
