I have a hub that i connect my periphereals to and i connect that hub to whichever pc i am using (i have 2) (also note that i plug in an ethernet cable too) now i have to manually connect it. i had a conversation with chatgpt and it said to get an auto switch which would basically detect which conncetion is alive and send the signals to that one. i searched a bit on the net but couldnt find it. what do you think about this? also i can use arduino or something too.
I know it might not be secure, yeah vibecoding is cool but we shouldnt do smt unless we understand it and etc. thx but these disclaimers get old quick. maybe we shall be reminded frequently for we are stupid but i dont work at a nuclear powerplant.
https://linustechtips.com/topic/1617296-auto-usb-switch/
11 minutes ago, emosun said:
called a kvm
yea but afaik they are manual
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763571
Wait you are looking for something that will auto-switch between devices depending on which one is... on? off? most recently powered on? I'm confused.
A KVM typically is a simple button press that swaps between the devices. That's the best solution that exists that I'm aware of.
ask me about my homelab
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763574
They can be automatic. The KVM built into my monitor will automatically switch inputs if it stops getting a signal from one of the computers.
You only need to use the switch if both computers are on at the same time.
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763580
yea if i have to press a button might as well change the cables too
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763593
yea but how can i plug my hub to 2 computers at the same time?
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763594
You plug the hub into a USB port on the KVM. That's what I do with mine.
I have an additional monitor with a built-in USB hub that I plug my mouse, keyboard, and microphone into. I plug that into one of the two USB ports on the monitor with the KVM switch (I use its other USB port for my webcam).
Now, the KVM will let me swap the mouse, keyboard, mic, and webcam between the two computers.
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763597
25 minutes ago, emosun said:
why do you use any of the light switches in your house then just unplug all the lamps
its about convenience
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763626
10 minutes ago, emosun said:
yeah so if a button is too difficult then unplug and move a bunch of cables right?
the thing is all the periphereals are connected to the hub so i just need to reconnect one cable, if the switch is not automatic i dont think its worth getting
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763637
When was the last time you used a KVM? Most KVMs I've ever used do automatically switch to the active input. This can be funky if two or more PCs are on at the same time are on, however every KVM I've used also has shortcut keys that you can use. So if you don't want to hit the button on the KVM you can use a key combination, or hit scroll lock twice, etc to swap between inputs.
Any of this must be easier than swapping around cables all the time. Much less, saving the wear and tear on the connectors which do have a limited life span.
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763725
so.. you want a device that automatically switches a USB connection between two computers depending on which one you're using... how would the device know which one you're using?
also, i have the distinct feeling we're talking about two laptops here, because sharing displays is not mentioned at all, and you mention swapping over an ethernet cable.
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763730
it defaults back to port one if nothing. turn on pc 2 and it switch.
its doable but finding it the problem. i have an auto hdmi and rca switcher. most usb switchers use a button or macro thow
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763745
never
one will suffice then
active voltage¿ (only one will be on at a time)
desktop + handheld ( i connect it to monitors)
as @thrasher_565 mentioned, i just need an auto usb switch
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763746
i think this can do auto scan but its costly and there a meh company...
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763747
looking for something super cheap
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763754
gl
i guess the monitor thing is the best if your monitor has it thow...
there just the hdmi
there this one
$20 hdmi one...
posably? 🤷‍♂️
3port hdmi
Edited by thrasher_565
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763755
47 minutes ago, thrasher_565 said:
gl
there just the hdmi
there this one
$20 hdmi one...
posably? 🤷‍♂️
3port hdmi
well the monitor thing is super neat but obviously i dont have it. also i need usb not hdmi 😅
https://linustechtips.com/topic/1617296-auto-usb-switch/#findComment-16763777
