So since I built my pc yesterday, my front bottom case fan has been acting up. The other two were fine, and they’re all daisy chained. It was off up until today, when my dad hit it a little to see if it would work, which it did. But then it started flickering and eventually it became significantly dimmer, which was fixed easily by hitting it again… until that didn’t fix it either. I need help. Edit: forgot to mention it is spinning normally, this is just the argb acting up.
https://linustechtips.com/topic/1616294-case-fan-acting-weird/
check the connectors
Or maybe you put too many fans on one header ?
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16756350
10 minutes ago, Blasty Blosty said:
If possible, yes
After some checking, I don’t think I can get it out. I don’t wanna replace the whole case because it was impossible to put in everything and do what little cable management I did, and I don’t want to do it again. Should I just leave it as is? It’s only the argb. It looks ugly but that’s the only issue.
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16756358
If that's the only issue, then yes I suppose it is up to you. Just keep in mind the issue may get worse over time, or it also may not, no real way of knowing.
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16756360
How's that ? I mean it takes me 5 minutes to swap a fan, 4 screws and a couple header to unplug?
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16756370
Can’t remove the fan, there’s no way to get the front off and the screws are near impossible to unscrew.
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16756613
Case came with fans already installed ? And front panel isn't openable ? Bwaah bad case 😞
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16756691
What case is it? They managed to put the fans in, so you should be able to get them out.
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16758320
the front pops off acrding to the pic. dont no if there screws or pins to push.
https://www.amazon.ca/FOIFKIN-K11-Case-Pre-Installed-Mid-Tower/dp/B0DHY1XXKC
https://linustechtips.com/topic/1616294-case-fan-acting-weird/#findComment-16763182
