Air Flow setup with AIO
Go to solution Solved by Hinjima,
3 minutes ago, WardedBowl403 said:
This is what I am thinking right now, the yellow is my Lian Li GA II LCD. I have also seen setups where the far right fan on the AIO is an intake but I am not sure.
This is exactly how I would run my system if I had an AIO and the amount of fans you have.
Thats how I did run it when I did have an AIO, worked wonderfully.
I wouldn't change anything here 🙂
