So, I have opted to go for Air Cooling over an AIO unit and I am looking for something that would be ideal for a non OC i5-4670k (or Devils Canyon equiv) but still have the potential to OC when I feel confident doing so, I Don't want hinder my Vengeance Pro RAM Modules. I will be wanting the Max level of cool while maintaining all four ram slots.
Suggestions and recommendations ?
https://linustechtips.com/topic/161216-vengeance-friendly-cpu-block/
So, I have opted to go for Air Cooling for an AIO unit and I am looking for something that would be ideal for a non OC i5-4670k (or Devils Canyon equiv) that wouldn't hinder my Vengeance Pro RAM Modules. I will be wanting the Max level of cool while maintaining all four ram slots.
clarify please? are you going from air to AIO? also why have a K SKU and not overclock? and why liquidcool it then.
to answer the question (assuming you are going for a AIO) no waterblock will interfere with your ram, since they dont hang over the CPU slot.
if you are going aircooling, the NH-D15 is optimised to work with tall ram
i see you edited your post. go for the d15 its great
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
That is going to be difficult, I think your best option is an AIO cooler.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
 I have edited for you :D sorry just got in from work and my brain farted :(
I would be looking to go for AIR cooling just to clarify.
Yeah I just heard stories of the units leaking and stuff and I'm not a huge fan of replacing expensive stuff GTX 770' etc. Unless my concerns are misguided :P
get something like a d15 then, and pelase for the love of god, overclock that CPU :D
and yeah your concerns are moot. maybe 1 percent of them will leak, and if they are under warranty, (atleast CM) the maker replaces all the stuff for you
Heh, I'm new to the whole idea OC'ing this will my first real build, so naturally nervous about it :P any advice on OC'ing would be great to.
just watch a few haswell guides to learn the basics, then do it yourself, but DONT USE THE SAME NUMBERS AS THE VIDEOS, try your own
I'm pretty sure its under 0.01% that leak. 1% is more like the failure rate. Failure does not mean leak :)
you are correct :)
You can get the NH-U14s NH-D14 or NH-D15 they are all compatible with vengence pro.
Ovbiously These are very very high end coolers so if you don't overclock with them its abit pointless :P Just watch some guides on how to do it, its actually really easy just be patient though, if you rush it thats how things go bad.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
