Help me return my sanity
Solved by AbydosOne,
2 minutes ago, Poinkachu said:If there's a thread on the outer side, and there's a needle in the middle of it. It's RP-SMA Female.
If there's a thread on the outer side, and there's a hole in the middle of it, It's SMA Female.
If there's a thread on the inside, and there's a needle in the middle. It's SMA Male.
If there's a thread on the inside, and there's a hole in the middle. It's RP-SMA Male.
Looks right.
