i'v been using Rog strix g15 AE for 2 years now, i wanted to do some thermal change because i noticed some performance drops over the last few months, prior change i ran some benchmarks and noticed that my gpu was only using 90-100 watts, temps were 84-85C overall, 80C junction and 102-103C hotspot, time spy score was 8k, cpu temps were hitting 97C on 30-35W usage, after thermal change cpu temps came down to 89C on 50W usage and gpu to 81-82C overall, 72C junction and 100-101C hotspot, but power consumption basically stayed the same it averages on around 95W TGP , i'v seen other people run this gpu on 86-87C on full 130W power so i'm confused why mine is using almost 40W less when temps got much better. time spy score didn't change. i used arctic tp-3 thermal pads 0.5mm and 1mm, for gpu and cpu instead of liquid metal i went for arctic mk-6.
https://linustechtips.com/topic/1610522-rx6800m-not-using-full-power/
Most laptop GPUs have multiple power targets which are determined by the Manufacturer when they design a model.  It can be drastic too, like a card that can run 150W but systems can be designed all the way down to 65W!
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
Is this done through vbios or?
In other words, can it be hacked?
-Scott Manley, 2021
Possibly I'm one to view anything that is accessible to be hackable.  Usually there is a reason for those decisions you will likely need to improve cooling for it to not be an issue.  Sometimes it is more of a battery life decision though.
The CPU in a gaming laptop needs a certain amount of wattage to maintain a stable framerate, I'd suspect laptop manufacturers set the GPUs max wattage availability with this in mind.
Its something easily demonstrated with handhelds, where stealing too much power from the CPU causes the boost clocks to be low enough to have a hard CPU limitation. The balance requirement in handhelds is more extreme than in gaming laptops, but the same theory applies when the CPU and dGPU are power sharing.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
Hwinfo64 indicates 130W as GPU ppt limit, gpu core wattage also peaks at around 120W at the start of a benchmark then it stabilizes at 95W range as temperature reaches 82C, i'm thinking maybe thermal paste doesn't provide enough heat dissipation. but i'm not sure since neither wattage nor temps are going up.
Paste may help but the actual heatsink area, heatpipes, etc is likely fairly limited especially on smaller devices.
Check the Windows power profile.
Use the latest drivers and the latest bios.
Check if your power adapter is strong enough. If the laptop was bundled with a 95W charger, there might be a benefit of obtaining a 120W one.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
But that's typical for throttling, temp doesn't go up because wattage gets limited in order to keep the temp stable...
Most GPUs max out at like 80-85c, any higher and something has to give, frequencies, wattage, etc...
For example my 4070 mobile has a limit of 87c, but it usually stays around 80-82... That's all I need to know and I honestly prefer that over 87c + hard throttling...
-Scott Manley, 2021
I doubt the laptop auto increases the gpu wattage when the cpu doesn't need it. and 90% of games need 35% of the power reserved for the worst case.
If you're thinking this deep (edit enough to create this topic), maybe a laptop isn't the best choice (vs Desktop + lower power laptop combo).
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
