Hi guys have a had a bit of a search and can't find what I'm after
I currently have a case with a dual system power supply ( phantex revolt X 1200w)
I am looking to replace it with another dual system power supply if anyone knows of any still around?
Here's the story for those interested I believe it's on its way out because it's crashing under high load, it started off randomly and then it graudely turned into everything I booted any game it would crash ( screen goes blank fans stop spinning but mobo leds and USB power flicker)
I swapped it from PC slots one to PC slots 2 and go lt another 2 days of completely fine use then now it has started happening again on slot 2 now so believe it is on the way out but I can't find any that are still like it and would like to still replace it with a dual system PSU because I'm the future I would like to use the dual PC features
Thanks for any help
https://linustechtips.com/topic/1609568-dual-system-power-supply/
only one i no of is the one you got. might need a case with 2 psu.
8 hours ago, Chaos_Potato said:
Thanks for your response hopeing someone does know of another as they are all discontinued to my knowledge 🥲
it was a bit of a gimmick. i no they had case that had 2 pcs and 1 psu and before that they had this thing to hook 2 psu 2 one...but i think that was before the duel chamber case that lots of them can have 2 psus. i guess no 2 pcs...🤔
for redundancy i would want a psu per pc so both dont go down. slight cost saving but meh
my dad got me a titanium psu and you think for $700 it atlest have 2 12pins... (not that i would use it...)
