1 minute ago, Felrin said:
I have an Arctic Liquid Freezer III 360 cooler, I want to make a push pull. How about Thermalright TL-C12C-S as a pull? Or should I get an Arctic P12?
In the real world, it probably won't make any difference at all.
Push pull or between fans? 馃槃
Between fans.
Any particular reason you want push/pull setup?聽 Are your temperatures bad?
You probably won't see a huge increase in cooling performance with push/pull over just push or pull.
Its primarily just a way to take up more physical space, possibly cause unwanted turbulence noises and cost money. AIO rads don't really have the fin density to benefit from it. Classic case of marketing winning. More fans = better, right?聽
Ryzen 7 7800x3D -聽 Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
TL-C12s are a tad on the weak side, but they work. I am using their TL-B12's and they are much better. I have not used Arctic fans, so no comment there 馃檪
T30s are little beasts. 120x38s will give you everything you need, including a migraine 馃槃
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
4 hours ago, OddOod said:
Meh, my partner has a corsair 280 AIO and when we slapped a second set of fans on it we did see ~20% better cooling
I have my doubts unless something else was changed. Would need to have seen the water temp before.聽
Remember, AIO fans aren't there to cool the CPU, they're there to cool the water.
3 hours ago, freeagent said:
TL-C12'ler biraz zay谋f tarafta ama i艧e yar谋yorlar. TL-B12'lerini kullan谋yorum ve 莽ok daha iyiler. Arctic fanlar谋 kullanmad谋m, bu y眉zden orada yorum yok馃檪
T30'lar k眉莽眉k canavarlard谋r. 120x38'ler migren dahil ihtiyac谋n谋z olan her 艧eyi size sa臒layacakt谋r馃槃
TL 21 euro, Arctic P12 (non ARGB) 30 euro.聽
T30s. Good fans, better than Arctic.
Expensive.
/shrug
Running the fans at the same speed gave lower CPU temps. That's all I wanted and all I needed. Now even on a synthetic load they don't turbo to jet takeoff speed
5950X/4090FE primary rig聽 |聽 1920X/1070Ti Unraid for dockers聽 |聽 200TB TrueNAS w/ 1:1 backup
