3 minutes ago, XVALUES said:
what would be a good case for water cooling before I dump money into it?
You could technically watercool in any PC case if you are experienced enough.
Most fish tank cases are quite easy to do a custom loop in.
The Fractal Torrent is massive so you have plenty of room.
https://linustechtips.com/topic/1606928-water-cooling-pc-case/#findComment-16692682
depends on how many  rads and how big. like other said most can do 2x 360
some can do 2x 420 and if you want bigger then that then you get a big case.
https://linustechtips.com/topic/1606928-water-cooling-pc-case/#findComment-16692868
