Need Help With Making Wired Network!
Solved by Atlantisman,
1. You can use pretty much any cable, if you need a lot of it i would recommend buying a spool, wire crimpers, key stone jacks, wall plates and etc.
2. Terminating a cable is simply putting an end on a bare wire.
Avoid putting the wires in the wrong order. use TIA568B standards on both ends. http://www.marcspages.co.uk/tech/lantwst5.gif
Here are some products you might find useful:
Patch cords are a little different than the wire that you would get in the spool i mentioned, they just have more flexible stranded core wires, vs that spool having solid core wires. stranded core wire is more flexible generally, rated for higher bend radius. refer to the image below:
