There is something i wonder for myself , i got my samsung 990 pro yestorday and i install there the game world of warcraft .
there is something i wonder if its my imagination or its a real thing , when i try to run the game on both 2 difrente ssd drives im getting the same FPS ofc ,
but the thing is even with the same FPS when i run the game on older SSD (sata ssd) the games feels moving smother like its not have a feeling that i have 70-80 fps its feels smoth,
but when i run the game from the new samsung 990 pro even that im getting the same fps , the game feels less smoth .
i tryed to run both games multiple times to see if its my imagination tricking me or its real thing ,
but each time that i test it on each ssd the game with the sata SSD feels run more smoth when i move or move the camera...
i dont know if its a real thing but thats what its feels to me after many trys back and forword ...
tell me what do you think can it be a difrences on how each ssd run the game ? or why i have this feeling after many trys ...
thanks for reading
https://linustechtips.com/topic/1603309-a-problem-or-not-on-ssd/
9 minutes ago, Adirna said:
it will take some effort to do so i think , dont know how to do it easy
if you have a camera or phone you can just record your monitor , and after you finish recording you plug the phone/maybe camera into a usb on your computer
Just now, strange13930 said:
if you have a camera or phone you can just record your monitor , and after you plug the phone/maybe camera into a usb on your computer
i'm not sure if you could see the difference like that , its not huge but there is some difference that you need to be on the pc to see it
are other games not as smooth between the two ssds
I would try to make sure its not a problem with the game
3 minutes ago, obtainhigh said:
Your FPS is the same, but latency and texture streaming might differ! The 990 Pro has aggressive power-saving—try disabling PCIe power management in Windows and Samsung Magician. Also, check if Resizable BAR is enabled in BIOS. 🚀🔧
Yes that is what it feels, I will try to look for this option on Windows, ‏the thing is when i tried ‏to search a bit for this kind of problem on google i didn't find anyone with the same problem as me so i don't know
i had it already the settings on windows for max performance also on nvidia control panel i change to prefer to max performance , but still same thing
Can you run crystaldiskmark, and crystaldiskinfo, and post screens from the two programs.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
Can you post whole smart table from crystaldiskinfo
crystaldiskmark score seams OK.
EXTERNAL
HDD/SSD :
Can you try to force it in uefi, to run on pcie 3.0, and see if games feel ok, and samsung benchmark will finish while on pcie 3.0?
there could be communication errors that we can’t see, smart table from crystaldiskinfo is ok.
ps. bclk is on 100MHz ?
EXTERNAL
HDD/SSD :
bclk 100MHz is on the CPU bios settings ? all settings are on default on the bios beside the memory XMP.
not sure i know how to force it to pcie 3.0 but i dont see a point to run the SSD on gen 3 even if it will fix the problem ... i didnt buy the most expensive gen 4 ssd just to run it on gen 3
I’m trying to troubleshoot the root cause, it could be the cpu, it could be mobo, chipset, Ssd, or even mounting of the Ssd.
try to take out the Ssd, and insert it again in m.2 slot, see if it helps.
in uefi there should be option to chose generation for each m.2 slot you have ( in the better ones there is ).  what is your mobo, and in what m.2 slot did you put it in?
Swapping m.2 slot could also be smart, do you have a free M.2 slot?
EXTERNAL
HDD/SSD :
i have x4 gen 4 nvme slots and only one on use with this ssd , i put the SSD on the closest nvme slot to the cpu , i heard its the best place to put it
Depends on the motherboard, in most of them you are right, and it’s m.2 slot connected directly to the cpu, and should be the best, but only if it works correctly.
I have seen people having problems that just putting out SSD, and Putting it back on again in M.2 slot helped. Sometimes it’s cpu related, as in cooler mounting pressure etc.
for now just put it in the lower m.2 slot, and give us your motherboard model name.
EXTERNAL
HDD/SSD :
Z690 GAMING X DDR4 (rev. 1.0) my MB
Yes, the upper m.2 on that mobo is connected to cpu.
we will wait for you to swap Ssd the the lower m.2 slot, and give us feedback, how the games feel, and if samsung magician benchmark is finishing without errors.
EXTERNAL
HDD/SSD :
