yeah its fine, the best stuff is IC diamond in my eyes but its expensive!
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/160177-cooling-paste/#findComment-2133435
expensive* thats been bugging me for ages :P
:) fixed sorry :D
}else{
https://linustechtips.com/topic/160177-cooling-paste/#findComment-2133446
I use industrial silicon compund that costs $2.50. I have used IC diamond, TX4, Silver 5. The difference is 2c...
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/160177-cooling-paste/#findComment-2133450
I have MX-4. It's more a question of applying it correctly and a clean mount, rather than the correct thermal paste. I have mounted my previous Dark Rock 2 multiple times with the wsame paste but with up to 10 °C difference because i did a better mount.
who cares...
https://linustechtips.com/topic/160177-cooling-paste/#findComment-2133473
It doesn't really matter, the difference in temps between a good and a bad thermal paste is like 2'c
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/160177-cooling-paste/#findComment-2133812
