Budget (including currency): 2000 usd
Country: Argentina
Games, programs or workloads that it will be used for:
Games I play: Beamng.Drive, Fortnite, Counter Strike 2, Grand theft auto V and Assetto Corsa (I don't do competetive gaming but I always play on low graphics to get the most fps)
The programs I use for school are Adobe Photoshop, Illustrator, Premiere pro, Audition and in the future After effects
The pc I built back in 2020 has Intel Core i5 10400f, 2x 8gb 2666mhz DDR4 ram (the max speed that my motherboard supports), nvidia rtx 2060 (I think its a gigabyte super dual oc), Thermaltake 600W 80 plus standard PSU, motherboard Gigabyte B460M DS3H AC. I have a 1080p 165hz principal monitor that I use displayport and a secondary old one 1366x768 that I use a HDMI to DVI cable.
I want to upgrade because the games I play doesn't run smoothly and I think I have a CPU bottleneck.
I don't know if I have to upgrade my whole pc or its more recomendable to just get a better LGA1200 CPU
Edited by oddfuturo
https://linustechtips.com/topic/1600237-i-need-advise-for-a-pc-upgrade/
Country: Argentina
Do you have a link to any sites or stores you will be purchasing from?
