Please check my build :D
7 hours ago, Happy Teaspoon said:For the motherboard, dont I need gen 5 pcie for the gpu?
no, and I think 50 series will be 4gen anyway, and it's forwards and backwards compatible
7 hours ago, Happy Teaspoon said:I already swapped out the PSU for the one you recommended, I didnt really think about the white cables. Im going through the rest of it now.
have you checked out the other NVMEs on that list? they might be cheaper while giving you similar performance as the one you have on yours
7 hours ago, Happy Teaspoon said:Oh as for windows I added it just so no one thinks Im doing a Linux build or something, Ill probably just do that hack to activate windows for free after you install the trial version.
sure, the middle way is to just download Windows for free on official Microsoft website, and then grabbing like 10-20$ key to activate it,
also if you want W11 and don't want to be forced to make a Microsoft account, there are videos that show how to skip that step during installation
5 hours ago, Happy Teaspoon said:Ok Ive updated the build. Ive cut it down to 1162 USD without the (import duties suck) I swapped out the case somewhere along the way, Im still seeing about switching out the aio. Im a little worried about airflow in the new case. Im watching reviews and stuff to see if an air cooler will be ok. My MB choice isnt ideal but most of the cheaper ones wont arrive until mid March
Thanks again for all the help, its helped a bunch!
in O11 vision, the idea is to grab fresh air from side intake and bottom intakes,
and GPU + last 1/2 rear fans exhaust, since there's many intake fans a good idea would be to run those bit slower than the exhaust fans, but no need to match even pressure, positive pressure is fine,
for AIO, you could swap to these if they're cheaper, or even use air cooler,
https://pcpartpicker.com/list/hBrMwY
Thermalright Peerless Assassin 120 White ARGB
