i bought my (xfx rx570 xenon e5 2680 16gb ddr4 z440) two month ago and i have be having issue when i play games it crashes so i thought its gpu as the pattern on the crash is vram so i did heaven benchmark for 30 mins no problem so i treid occts vram test for 30mins nothing and the game that this happens the most is cpu intensive  hoi4 but when i check the crash logs gpu will not respond to more comands i even did a furmark nothing but when i did occts power test it crashed and the power button flashed 6 time + its innconstant i have went a week without crashes but now i cant play any games +i went to computer repair store and it worked fine am confused as to what is happening
https://linustechtips.com/topic/1597626-gpu-falling-or-electrical-issues/
Do you have a spare pc to test with? If not ask a friend to borrow his pc for testing.
Put your gpu in another pc to test, put his gpu in your pc aswell.
Is it a RX 570, and was it used already when you bought it?
I usually edit my posts.
Refresh the page before answering to my post.
used and no i dont have a spare and i dont think anyone would give me a pc can i try anything but can it be gpu even that heaven and furmak work fine
Problem with old used parts is that they're prone to degradation and failure
I'd start with cleaning and repasting the card
Can't you pick out the gpu and visit a friend to test it over there, just to be sure?
10 minutes ago, will156216 said:
i did repast it
and how are the temps? hotspot temp good?
current PC:
PC configs I used before:
about 86 under furmak 81 under reguler use like games but i wanna try to under clock it but i dont know how much without giving too much perfomance away i have one exsast fan so the air flow isnt that good i think that the cpu heats up the case in games so the gpu over heats
yeah those glitching artifacts are GPU related,
you could still hope it's one of the VRAM chips and as long as those aren't used the rest will function normally, or something similar,
not sure if underclocking will help, reducing % power draw might work better,
on modern GPU, if you underclock, the GPU will just boost back, because it has enough temp room, voltage, etc.
current PC:
can this be related to the areas electrcty or the gpu and i did a vram test and  its fine
Unless if you use some of the worst PSU in the world, no, stabilizer can only do so much. This is GPU artifacting.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Glitching (artifacting) like that is a classic VRAM issue.
Unfortunately, not much you can do about it although you could using MSI Afterburner to try and lower the memory clock on the GPU to see if you can find any stability but still have enough performance to play games.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
so the i have a warrnty the thing is i went to the guy and the pc worked fine there so he didnt rma it and it does this on a cpu game like hoi4 doesnt use gpu alot
also its not happening always two days works fine then other days it doesnt work and i cant play any games can hardware issues be like this
that's undervolting, if you "under clock" it usually adheres to the maximum set, you can even lock the clock speed with afterburner...
that said, ops gpu is probably toast. sorry to say.
-Scott Manley, 2021
then why is it working fine in any striss  test and some times rare that it does this on the home screen but i works fine in any benchmark how can this toast tho
because if stress doesn't "load" the VRAM on data it has to store, it might not do the same problem
current PC:
6 minutes ago, will156216 said:
the weird thing i got the vram speed back and it works today nothing wrong
well, if the GPU has problem, it doesn't always have to crash or glitch
it can work fine like nothing is wrong, and then suddenly crash/glitch few days later for example
current PC:
2 minutes ago, will156216 said:
so i should rma it
yes
a dying GPU can definitely be intermittently okay. It's a maddening hunt for the problem. But that artifacting is a huge red flag
the guy just says it works fine cuz it works fine there cuz i cant sit and play for an hour so what should i do
