1 minute ago, koopa990 said:
From laying my PC flat on a box to everything else.... I want to give up. Maybe... This'll be my last resort: handing my PC to geek squads
Are you asking or help or just ranting?
We need more info if you want help.
If ranting, sorry?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 32GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 128GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
That's a board, what's the cooler and the problem ?
Usually if it's "very hard" you aren't doing it correctly (talking from experience 😛 )
So hold it?
Not sure what the problem is.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
9 minutes ago, koopa990 said:
There's no way to mount the plate directly on the board, I gotta hold it
Yes, if you are mounting a cooler that requires a backplate after the motherboard is already installed in the case, you do usually need to hold it in place until you get at least one of the screws in.
This is one of the reasons why, when you're installing the cooler initially, it's done outside of the case.
I had to do this when installing the Vetroo V5 into my now secondary computer. It was difficult, but doable.
You can also use tape to hold the backplate in place, as long as the force you use to drive in the screws isn't too great.
Another option would be to take the motherboard out of the case and install the cooler with the motherboard on a box or something, or you can get someone else to hold the backplate up for a few seconds while you get a couple of screws in.
EDIT: Another idea - if you have a box or something of the right size to fit through the hole in the back panel of the case, you could put your case on top of the box, and have that prop up the backplate - assuming your case isn't so heavy that you'd risk cracking the motherboard if it put too much pressure on it.
EDIT: Another idea - if you have a box or something of the right size to fit through the hole in the back panel of the case, you could put your case on top of the box, and have that prop up the backplate.
2 of those options I can't succeed:
1. I have no one to help me
2. I really don't want to unplug everything just for this
It takes 5 minutes.. you should really be doing this outside of the case.
I still have the terrible memory of me plugging in the stuff in correct slots. Plus the tremendous force to push
Wait, this is a reinstall of the cooler?  Can you backtrack how you took it off?
What cooler?  There are instructions for them....
OnePlus Ecosystem:
3D Printing:
You don't need to.  I removed my AIO and put on a Peerless Assassin inside the case.
You need to figure out how it attaches, if it is screws and springs, you need to push until the threads catch.
Yes, it can be a good bit of pressure.
OnePlus Ecosystem:
3D Printing:
I've definitely never done this and probably never will...?
i also close all side panels before turning the pc on for the first time,  sue me... 😂
that said im not sure i understand ops issue... don't all coolers need some kind of "brackets"...??
where are ops brackets? im thinking that's the issue.
@koopa990  what cpu do you have (which we conveniently can't see due to the beautiful blob of thermal paste lol) and what cpu cooler do you have?
7 minutes ago, koopa990 said:
This model isn't push. Needs back plate in place, screw in
yeah. all cpu coolers need a backplate,  i don't think that's actually the issue,  we need the correct information for parts in order to help you.
-Scott Manley, 2021
28 minutes ago, freeagent said:
So hold it?
i LOVE remounting the cooler while the backplate is just a loose useless thing threatening all SMD parts of your mobo... TESAFILM to the rescue!!! 😂
@YoungBlade that's actually why all cases have cutouts in the back so you don't have to mount the cooler outside (how barbaric!) but it's indeed a pain.. you can hold it as @freeagent says, but really better to use something like not super adhesive tape, aka tesafilm, or whatever you guys use.... America has tesafilm, right? 😭
-Scott Manley, 2021
can be done in 5 minutes inside the case too,  but you definitely need "something" to hold the backplate in place ... that said... we still don't know what cooler op uses so....? ¯\_(ツ)_/¯
-Scott Manley, 2021
11 minutes ago, koopa990 said:
Ryzen 5 3600
Wraiths cooler (not the stealth and prism model)
yeah. you need the AM4 brackets, WHERE ARE THEY? (comes with your motherboard btw)
-Scott Manley, 2021
Amd wraith
Amd wraith
see above.  you need the brackets that (should have) come with your motherboard.
Screenshot_20250103-215542_SamsungInternetBeta.png.5d1e7b20720333af91bef2c8c2864d7f.png
something like this?
-Scott Manley, 2021
It may be easier for you to tape the backplate to the board, if you're having trouble screwing the cooler in while it's in the case and holding the backplate at the same time. Otherwise removing the board from the system and doing it on a flat surface with the board on top of the backplate holding it down is much easier.
The AMD stock coolers that are installed by screwing into the backplate can be a little tricky if you've never done anything with that type of mounting before. Typically once you get one in it should be easier to get the rest. Keep in mind you do not tighten them all the way one at a time. You get one threaded, then thread the rest, only a couple turns just enough to get them all started, you then gradually tighten them all in an alternating pattern, evenly tightening them, you do not fully tighten them individually or one at a time. There are guides on how to install these coolers properly.
Also remember to repaste your CPU, if you are installing the cooler with the intentions of using it with the past looking like it does in the picture, just know that you'll likely run into overheating.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
the brackets may also come with your cooler but wraith uses the standard ones that come with your mobo iirc. you also definitely need a backplate.
-Scott Manley, 2021
