Just now, Eden4422 said:
Hey so I am looking for a case (ATX, Mid-Tower)
I want something with good airflow and with fans in the package, RGB would be nice but Id also like to keep it <$100 USD
Needs to support a 340 mm GPU
also I should add i plan to use the Aqua Elite V3 as my AIO cooling, going with a black build
LL O-11
Corsair 4000D Airflow
Phanteks NV5 (though if you can find an Eclipse P400A in stock anywhere, those were discontinued but usually 75$ and a dream to build in)
4 minutes ago, OddOod said:
LL O-11
what fans do you recommend or do they come with fans?
I am a bit of a case slut, I have had a LOT of them over the past few years before selling them/giving away etc. The Phanteks NV5 is the first one I have used for more than a year while not getting the itch for something else. It is a GLORIOUS case. There's a lot of good options currently but the NV5 is where my search would start and end
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
is the MK2 about the same? I cant seem to find the original model Nv5 anywhere
They are literally the same case, except Mk. 2 also supports back connection mobos, that's it
1 minute ago, Eden4422 said:
scratch that i found it in white, what fans should I get for this case?
Do you want performance or RGB or both?
15 minutes ago, Eden4422 said:
performance is more of a priority than RGB, but if theres a good fan that has both for a decent price then sure
I would personally get Lian Li P28s then. They have a triple pack for like $39 sometimes on sale. 99% as good as Noctua's best for a third the price. Be Quiet Silent Wings 4 and Phanteks T30s are good too but more expensive. You can go even cheaper and grab some Arctic P12s or something but I think the P28s are a good one for sound profile, performance, warranty etc.
would these be good? https://pcpartpicker.com/product/DtPQzy/arctic-p-pst-689-cfm-140-mm-fans-3-pack-acfan00255a
8 minutes ago, Eden4422 said:
Those are okay, not my favorite option
thrmalright has the best fans for the price even argb. even white fans...
Edited by thrasher_565
Thermalright kicks ass.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
honestly finding aftermarket fans is a pain in the ass sometimes, is this a good case? https://pcpartpicker.com/product/2MwmP6/montech-air-903-max-atx-mid-tower-case-air-903-max-b
ya its a good case.
ya with out being in the loop its hard to no whats good whats not.
