Intel(R) Bluetooth - Connect and Disconect Loop
Solved by esCaPade1,
Hi. If your Bluetooth receiver is a USB device, try it in a different USB port.
If it is built in to your motherboard, however, I'd try making a bootable Linux drive and booting into it - if you see similar issues in a different OS, then it is definitely a hardware issue and nothing to do with drivers. You can use a tool like ventoy or rufus to make a bootable drive, and Mint or Ubuntu should be good options for testing.
If it turns out to be hardware, you can contact the motherboard manufacturer for support. If it is out of warranty, however, I'd just splash out on a Bluetooth USB dongle - about 15 dollars/euros/pounds - and disable the built-in one.
