I've been planning a build for quite a while, and I want it to run Watchdogs. I know it's a badly optimised game, so I'm not expecting a solid 60fps, but I want smooth gameplay.
I have two choices that are within my budget:
1) GTX 760 + i5 4440
OR
2) R9 270 + Xeon 1230 V3 (Equivalent to a 4770)
Which option would you guys choose?
Edit: I know that it's a GameWorks title, meaning that it'll run better on Nvidia cards. Please just reply with what option you would take
https://linustechtips.com/topic/159055-cpu-for-watchdogs/
The optimisations are more dependant of the GPU you play with! My Fx 8320 has all the cores loaded at around 60% when playing this game and I see almost no fps increase or decrease when overclocking. So get the GTX 760 or even higher if you lower to I3.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2119231
At the moment Watchdogs isn't very well optimised for AMD cards, however this should change in the future.
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2119243
the 760 will give you better frame rates but with a 2gb card you are limited to using the lowest texture setting, 4gb is required for ultra and 3gb for high (the game state 3gb and 2gb but the real usage is much more) nvidia card run,s watch dogs better ATM, AMD will probably have to come out with a new driver to improve cause ATM the r9 290 perform about the same as a 770 and it should not be it's a much stronger card...BTW this game really aint worth building a PC for it, it's not even worth buying if you want my input on it it totaly sucks, they've created a big hype around this game and it looks awesome in the TV publicity and all, but for real even on ultra its really not that good looking, the physics is terrible it's not realistic at all...really i havnt been that disapointed by a game in a long time, here listen to this video, it highlight many flaws in this game, it's ridiculous this game should cost 29.99$, GTA V can rest easy :
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2119392
Still don't know what card the link shows...I'm in the UK btw
Oh yea then you probably cant get that card for the price.So a 270 and a i5 would be good. Good Price to performance there.well actually,what s=is your budget like for the CPU nad GPU?
† TTCF Member † Jesus loves you! Have a good day and stay techie!
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2119529
Any difference between the i5 and Xeon for this game?
are you interested in just watch dogs or other games as well? and if so what games are you looking to play on this system?
the thing is AMD cards are very agressively priced and you get more performance for your money going AMD atm but they perform worse in watch dogs ATM at least until AMD release new drivers and maybe forever we don't know...
For CPU i would defenetly pick the xeon because it is hyperthreaded and is basicaly a core i7-4770 for much less...watch dogs do make great use of more threads processing, it run 8 heavy line of codes at once on 8 threads capable CPU like the core i7 or FX 8 core...
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2119538
No. No. No.
Why? Because the gpu is going to run at 99% on any cpu you can get all you can do is improve your frames is getting a better gpu.
The difference starts to be noticeable when you put 2 500$ cards in SLI and thats way above your budget and the difference between the i5 & xeon is 10% at best with 2 780's. With a single 780 same story above "No. No. No."
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2119649
You won't need a buff card for an application that depends heavily on graphics card. Watch Dogs is poorly optimized. Even a Titan can't run it past 60fps. Get a mid-semi high end card(GTX 770/ r9 280x), and wait for patch fixes.
Some people say the pirated version is better than the legit one.
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2120402
AMD is fine for Watchdog's. That said? I5 K is the best gaming chip for the money, even on "8 core games". You will not find a more forgiving site to AMD than GameGPU. The Tom's Hardware is comparing a low clocked I5 Ivy Bridge. Ivy Bridge ain't Haswell and Ivy on a OC would beat a 8350 OC.
SLI.
http--www.gamegpu.ru-images-stories-Test
Xfire.
A site that isn't as AMD friendly (gamegpu benchmarks often go against other sites) and looks to have actually benchmarked driving (where the big dips are).
The AMD is a fine gaming chip for Watchdog's and it's value isn't bad (if you go 8320 and a cheap board). Selling it as better than the I5 for GAMING? No.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2121010
so you say?
http://i.imgur.com/HKyZxJP.jpg
http://i.imgur.com/r7BOeIe.jpg
http://i.imgur.com/2jrYkdB.jpg
Look at the vram usage.
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2121068
what resolution are you playing at bro?
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2121134
cant you see?
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2121138
cant you see?
well maybe they fixed the game today i havnt played since yesterday, or my gpu behave differently the absolute lowest i seen was 2650mb with high texture setting...what card are you using? a 2gb card? if so the game probably scale according with the vram amount available..
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2121156
Watch dogs runs better on Nvidia cards. But anyway, it's even worse than assassins creed black flag when it comes to optimisation, such a disapointment.
No, there's a new patch out, it came it yesterday optimizing it more.
Case: Thermaltake Core V71 CPU: AMD RYZEN 7 1700X (overclocked to 4.1Ghz) Cooling: Corsair H110i GT(Push-Pull config) Motherboard: Gigabyte's Aorus AX370 AM4 K7 RAM: G.SKILL 2800Mhz 32GB GPU:  GEFORCE GTX 1080 (SLI) from Gigabyte Storage: Kingston 3K 240GB (main boot drive) Crucial M500 SSD, WD 2TB Green, 100GB HD(As backup) PSU: Sseasonic X Series 850W Gold
https://linustechtips.com/topic/159055-cpu-for-watchdogs/#findComment-2121180
