Morning guys,
I want to get myself a new gaming pc and put some parts together, It would be awesome if you could take a look at it and tell me what to improve so i get the most out of my money,
And is it even worth it to buy a PC now, or should I wait till Christmas when the new Intel CPUs come out.
My PC so far: https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/c51ff62206e878a368463b1385c8beab6cda13c6af2a37d99b7
Thanks a lot for your answers in advance.
https://linustechtips.com/topic/158887-gaming-pc-help/
Hi!
The 4670k is a very solid CPU. For gaming, that thing will be sufficient for quite some time.
About the PSU: That is just fine, maybe think about a modular one for better cable management.
One thing you should consider, is that you will not be able to SLI with that motherboard. I am a fan of smaller or small cases. They also sell a Define Mini and you could use that, still  have good airflow, silence (it is just a small R4 Mini) and ATX will not help you with anything, unless you have like a ton of other expansion cards....
And this way you would have a smaller case with basically all the same features.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117152
Thanks for the quick answers.
@Coombzy I could do that i guess. Thanks. :) Any tips? Should I stick with Corsair ones?  P.S. I just looked at the side and the 550 PSUs are more expensive than the 600w one :) so I´ll stick probably stick with the one I got there
@shiftberry I´m not sure about the mobo either. But I dont really want to spend more than 1000 Euros and Gigabyte Mobos are much more expensive. Do you know any good mobo for around 80€ or 110 USD?
@mapegl Yeah a modular would be better, but I dont have so much money as a student and they are usually more expensive. I know that I won´t be able to do SLI with that mobo. But I didn´t find a better one yet. Small cases are nice, specially the mini Define R4, could you please recommend me a mATX mobo? In case that I´ll get the small case.
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117199
This one?
http://www.mindfactory.de/product_info.php/Gigabyte-Z87-HD3-Intel-Z87-So-1150-Dual-Channel-DDR3-ATX-Retail_856361.html
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117216
Well considering, that you are on a budget, I would probably go for the MSI Z87M-G43. MSI's boards are quite solid and this one is actually cheaper than the ATX board you chose.
But the suggested Gigabyte one looks really nice and is only slightly more expensive.
Last suggestion: http://www.mindfactory.de/product_info.php/530-Watt-be-quiet--Pure-Power-L8-CM-Modular-80--Bronze_757838.html
EDIT: Do you have a CPU cooler? You should definitely get one, the stock cooler will not be able to handle much overclocking! I am selling a high-end one right now on ebay, but whether you want mine or not, get a better cooler!
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117272
Thanks, but the PSU i got now is 600 Watts and way cheaper :) I don´t know about the cooler. I definetly don´t need a high-end one.If I should get a cooler it would probably be the beQuiet! Dark Rock Adv. C1. But I don´t plan on overclocking right away. So I will probably buy the CPU cooler afterwards if I feel like I need more performance. And the mobo you suggested isn´t bad, but it isn´t capable of SLI either and it got only 2 USB 3.0 ports.
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117479
Ok thanks :)
I better ask one more time to be sure. Is right now the right time to buy an entire gaming PC?
Or are there any releases in the near future so my PC will be outdated soon.
take a look at this discussion, it might help you ;)
http://linustechtips.com/main/topic/158562-is-lga-1150-ending-this-year-or-next-year/
your pc is massively great atm and will still great even with the newest games' demanding requirements.. i still see C2D E6600 or C2Q Q6600 CPU with a good Geforce/ATi DX10 GPU runs just fine newer games! most of the games work with a dual core CPU but in the future they will need quad core CPU which you have at the moment..   :)
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117694
Ah thanks :) that helped a lot :)
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2117727
Yeah, and my CPU (a 2500k which has almost the same gaming performance as the CPU you picked) has almost the same performance in games with/ without overclocking, but in the future this will come in handy. Not enough CPU Power? Then just go from 3.4 to 4.5 and you are ready to rumble! Unlocked CPUs are awesome for getting more performance later on.
Also today you can achieve better performance with these CPUs when running a server an playing a game at the same time.
So all I am saying is: You have picked your components really well!
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118186
Thanks that you see it like that :) Is 4.5GHz easy to clock with a decent cpu cooler?
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118219
Should be. The better your CPU-cooler, the easier the overclock. I try to keep my CPU below 70°C (I think Haswell can run a little hotter) and it helps keeping things stable. I had no experience overclocking till like half a year ago, and now I have done several overclocks, on several mainboards with the i5 2500k. So I would say, yeah it should be possible after some reading and testing.
Your biggest concern should always be the temperatures, and also keep the voltage as low as possible. Higher temperatures might damage your CPU over time and due to the way electricity works, high temperatures lead to instability.
I try not to go over 1.3 on my core. But for that, just hop over to the overclocking section and ask people with the 4670k. There ought to be tons of people with that CPU.
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118256
Statt dem i5 würde ich lieber den Xeon 1230v3 nehmen. Der lohnt sich durch 8 Therads deutlich mehr, als ein übertakteter 4-Kerner. Zum Beispiel Watch Dogs lastet den Xeon gerade mal zu 20% aus, profitiert aber von den 8 Threads. Übertakten kannst du damit leider nicht. Ich würde auf jeden Fall Abstand von Corsair nehmen! Single Rail ist nicht zu empfehlen. Stattdessen würde ich lieber das hier nehmen: http://www.mindfactory.de/product_info.php/500-Watt-be-quiet--System-Power-7-Bulk-Non-Modular-80--Silver_822190.html Das hat auch eine 80+ Silver Zertifizierung. Windows 7 bekommst du bei ebay für 30€, deshalb würde ich es auch nicht bei Mindfactory kaufen. Statt der EVO SSD würde ich die Crucial M500 nehmen. Die kostet weniger und hat die besseren Komponenten verbaut:  http://www.mindfactory.de/product_info.php/240GB-Crucial-M500-2-5Zoll--6-4cm--SATA-6Gb-s-MLC--CT240M500SSD1-_844176.html
MfG Simon
"Instead of the i5 I would rather take the Xeon 1230v3. Instead of the Corsair I would take that: http://www.mindfactory.de/product_info.php/500-Watt-be-quiet--System-Power-7-Bulk-Non-Modular-80--Silver_822190.html This has an 80 + Silver Certification. You can buy Windows 7 for 30€ on ebay. Instead of the EVO SSD I would take the Crucial M500. It costs less and has better components: http://www.mindfactory.de/product_info.php/240GB-Crucial-M500-2-5Zoll--6-4cm--SATA-6Gb-s-MLC--CT240M500SSD1-_844176.html"
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118274
MfG Simon
Hey, danke erstmal für die Antwort. :)
1. Mit dem Xeon bin ich mir nicht ganz sicher, da ich bisher nur von der Intel i-Reihe fürs Gaming gehört habe. Und ja Watch Dogs würde ich spielen wollen :)
2. Meinst du denn 500 Watt reichen mir aus? Wenn ich den i5 nähme und den übertaktete? Und was genau ist an dem Corsair denn schlecht? Die Bewertungen sind auf jeden Fall besser :) (Kenne mich nicht mit PSUs aus)
3. Windows 7 wollte ich mir bei Ebay auch erst kaufen, aber habe dann gelesen, dass das nicht ganz sicher sein soll, obwohl man ja PayPal Käuferschutz etc hat.
4. Und mit der Crucial sparte ich ne Menge Geld, kaufte ich die SSD, nur die Leistung der Samsung ist ja auf jeden Fall in der Schreibgeschwindigkeit um fast das Doppelte besser.
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118438
 Yeah thanks, might do that but I probably won´t overclock in the beginning :)
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118494
Der Xeon 1230v3 ist ein i7 4770 ohne Grafikeinheit. Die brauchst du eh nicht, weil du ja eine Grafikkarte hast.
Das Problem am Corsair ist, das es Signle Rail ist. Multi-rail Netzeile sind einfach sicherer. Außerdem ist das bequiet leiser und effizienter (80+ Siver), Das Corsair ist nur so lange leise, bis sich der Lüfter anschaltet und das passiert bei 50% last. 500 Watt sind mehr als ausreichend. Beim Kauf von Windows 7 über ebay solltest du beachten, dass du nicht den Key via Mail bestellst. Du solltest ein Angebot mit Lizenzaufkleber und DVD nehmen. Wenn der Key dann nicht funktioniert, greift der Käuferschutz. Die Samsung ist nicht schneller, die angegebenen Werte wirst du nie erreichen. Ich konnte schon beide Ausprobieren und es gab keinen Unterschied.
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118504
First thing, although I am German, I would always write in English. Many others here are from other countries and it is also bad for you, when they cannot reply. Don't take this the wrong way, just makes the forum better, because everyone can participate.
1.) I also thought about the XEON, it has its advantages, but most games will not have great performance increases due to 8 cores. So.....I guess that's up to you. I would go for an i5 and have better performance/core, although I understand what @thesimon means.
2.) 500 watts is plenty for a high-end system. Don't worry. I actually measured off the wall with my system, GPU and CPU overclocked and got 370watts. Accounting for power loss due to efficiency, there is still headroom.
3.) Get windows 8.There is no big difference, but if you opt for gaming it will actually improve performance, slightly, but it will. And firing up your computer is super fast with an SSD and win 8.
4.) Samsung builds great SSDs and the EVO has been tested to last incredibly long in a consumer environment.
5.) (just saw your new reply) just make sure you ground yourself (Du solltest dich erden!). Have a clean environment and enough space! And watch a video from Linus's build logs. He actually shows really well what to look out for.
EDIT: I have a Single-Rail PSU from BeQuiet, and I would say that is also just a preference thing. It really depends on the overall quality of the PSU. I wouldn't get a budget single-rail PSU though, thesimon is correct when saying, that multi-rail is safer!
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118506
1. Yeah I watched Linus video already. I´ll stick with the i5 I suppose, because I havent really heard of the Xeon in consumer PCs before.
2. And ok I´ll get the 500 Watt be Quiet PSU since you all think it´s that great :)
3. I could get Windows 8 but I don´t really like the UI. And I am a pretty satisfied Win 7 user :) And it is more expencive than Windows 7 on Mindfactory or eBay.
4. I am not entirely sure. I know that Samsung makes really great products, but it´s a lot of money i would save there.
The thing with the DVD is for sure :) but I don´t know about the SSD now.
https://linustechtips.com/topic/158887-gaming-pc-help/#findComment-2118582
