Budget (including currency): $2500 USD
Country: USA
Games, programs or workloads that it will be used for:  Valorant, CS2, Dead by Daylight, R6 Siege
Current PC specs:
Motherboard - Asrock B365 Phantom Gaming 4
CPU - Intel Core i5-9400F
GPU - Nvidia GTX 1660-Ti
Drive - Intel 660p NVMe PCIe M.2 1TB
RAM - TEAMGROUP-UD4-3200 2x8GB
Case - NZXT H510
Cooler - Deepcool Gammaxx GTE V2
PSU - 500w Bronze
Refresh Rate: 240HZ at currently 1920x1080 but would like to be able to possibly upgrade to higher resolution and refresh rate in the future.
Why I'm upgrading: Recently noticed my PC has been having trouble with running games which comes as no surprise to me seeing as it is now 5-6 years old, I am wanting to upgrade, would like to save any parts I can from current computer but also understand if it makes more sense to just scrap the computer completely and start from scratch
https://linustechtips.com/topic/1585489-help-with-pc-upgrade-pls/
It's going to have to be a CPU+GPU upgrade. This also means changing the motherboard, the PSU and possibly the RAM as well, depending on your needs.
Building a 58 or 5700X3D with mostly second-hand parts would be the cheapest option as you'd be keeping your RAM, whereas getting an AM5 CPU would be costlier but future-proof. Intel has fixed most of its problems on the LGA1700 platform but AMD is still better value overall.
Ideally, you'll want at least an RTX 3080, 4070 or an RX 6800 if you want those 240 fps in CS2 to make your monitor worthwhile. That would also mean upgrading to a PSU that can feed at least 700W.
Ryzen 7 5700X3D (CO -30) - AX370-Gaming 5 - 2x16GB @3600C18 - EVGA RTX 3070 8G XC3
[PBO2] CO -25/-25/-30/-30/-30/-30/-30/-30
[BIOS] Vsoc 1.1 / DRAM XMP
i5-6400 4.38GHz @1.36v (162.2 BCLK) - Z170M-Plus - 2x8GB @3244C16- Biostar RX 570 8G w/ MSI Armor cooler
[BIOS] BCLK: 162.2 (x27) / Vcore 1.35 / DRAM 3244 (XMP timings) / FCLK 1GHz (1622) / RebarUEFI patched
ROG G531GT : i7-9750H (uv) - GTX 1650 +700mem - 16+8GB @2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore -160 / Vcache -105 / iGPU+unslice -125 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://www.asus.com/us/displays-desktops/monitors/tuf-gaming/tuf-gaming-vg27aqml1a/
PCPartPicker Part List
CPU: *Intel Core i7-14700F 2.1 GHz 20-Core Processor  ($318.61 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: *MSI MAG Z790 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($217.89 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($84.97 @ Amazon)
Storage: *MSI SPATIUM M482 Eco-Pack 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ MSI)
Video Card: *Gigabyte WINDFORCE V2 GeForce RTX 4080 SUPER 16 GB Video Card  ($999.99 @ Amazon)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($65.00 @ B&H)
Power Supply: *be quiet! Pure Power 12 M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.90 @ Amazon)
Monitor: *Asus TUF Gaming VG27AQML1A 27.0" 2560 x 1440 260 Hz Monitor  ($369.94 @ Amazon)
Total: $2326.28
Generated by PCPartPicker 2024-10-14 02:53 EDT-0400
Country: USA
Current PC specs:
Case - NZXT H510
PSU - 500w Bronze
You can reuse the case, but it has poor airflow, especially by today's standards.
The NVMe drive can also be reused, but replacing it with a significantly better performing model is not that much more.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($590.02 @ MemoryC)
CPU Cooler: Thermalright Peerless Assassin 140 77.8 CFM CPU Cooler  ($46.90 @ Amazon)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($149.99 @ MSI)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($85.99 @ Amazon)
Storage: Western Digital WD_Black SN850X 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: Gigabyte WINDFORCE V2 GeForce RTX 4080 SUPER 16 GB Video Card  ($999.99 @ Amazon)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($96.99 @ Amazon)
Power Supply: Enermax Revolution D.F. 12 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Amazon)
Total: $2179.85
Generated by PCPartPicker 2024-10-14 02:00 EDT-0400
https://pcpartpicker.com/list/knL9qR
265k + 7900xtx + 32gb 6400c32
https://pcpartpicker.com/list/PL9cZJ
7950x3d + 7900xtx + 32gb 6000c32
pricing on the 7800x3d is a joke even with microcenter bundles cause if you buy a microcenter bundle you might aswell get the 7950x3d version with a better board and 8 extra cores for only an extra 100$
both builds are relatively overbuilt considering the boards aios psus so you wont have to worry about the board cooler or rams upon cpu upgrade nor will you have to worry about the psu upon gpu upgrade
4080 super would raise build costs by 170$ and have worse non rt performance so unless you need nvidia features id just stick with the 7900xtx
theres still 600$ left you can use for a monitor upgrade so you should be able to get a pretty solid monitor heck even an oled monitor like this though id personally rather get an oled tv than an oled gaming monitor cause then i can use it to watch movies aswell =p
