Hi, can anyone with lg c3 or simmilar oled help out. I have a c3 and recently i went to clear the tv display. Tv is mounted on stand and set on cabinet. However i noticed that when i started to clean the display tv has a lot of wooble on the stand. All the screws are tight. Is the woobling normal?
https://linustechtips.com/topic/1584649-lg-c3-oled-stand/
Yes, some wobble is normal. As long as it doesn't wobble around with you just walking around the room, it's completely normal.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1584649-lg-c3-oled-stand/#findComment-16541218
