SATA Cable Shortage
Go to solution Solved by Dedayog,
25 minutes ago, PROHTC said:
Hey Guys,
                I am in the process of building a new PC. It will be my first time and I have done my research regarding the building aspect but have one issue. I will be using 3 SATA Drives (1 SSD and 2 HDD's). The problem is that my motherboard and PSU both come with only 2 SATA Cables. I could obviously buy more cables but since the PSU is a fully modular one I would be hesitant as I have heard there can be serious issues if the cables are not compatible. I tried researching and a couple things came up such as daisy chaining or using splitters however I have no idea how to go about it. I would really appreciate if you could help me in solving my problem. The links to the PSU and MOBO are below. I don't think that the entire specs of the system are required but if you do feel free to ask.
MOBO: https://www.msi.com/Motherboard/MAG-Z790-TOMAHAWK-WIFI/Specification
PSU: https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
Help would be appreciated.
Did you actually LOOK at the PSU cables?  There are multiple connectors on each cable.
Also, just get the data cables off Amazon or any other seller, they're cheap.
Hey Guys,
https://linustechtips.com/topic/1583962-sata-cable-shortage/
Hey Guys,
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1583962-sata-cable-shortage/#findComment-16532919
You have a molex cable. You can get molex to sata power adapters for next to nothing.
edit : Also, what Dedayog said. Each cable have multiples connector on it. Not just one.
https://linustechtips.com/topic/1583962-sata-cable-shortage/#findComment-16532920
2 minutes ago, PROHTC said:
Thanks for the pointing out the answer. I appreciate it. That was exactly why I was confused in the first place because it had multiple connectors but it said 2 cables.
You will still need to buy a 3rd SATA data cable, unless you already have one.
https://linustechtips.com/topic/1583962-sata-cable-shortage/#findComment-16532923
There is a saying, "Molex over SATA, Lose all your data"...
https://linustechtips.com/topic/1583962-sata-cable-shortage/#findComment-16533098
