Going to be building my first plex. I ordered 5 8tb drives, but forgot to check if the are sata, so 5 sas drives, so ok going to use them, make lemonade and all that, how would I attach them to an old pc (4 years old), I looked at raid cards though most are vague on of the support sas, how fast should I be looking at for a plex (8 gig pope to much?) Is there a better way of make a raid setup? Thanks in advance for any help!
https://linustechtips.com/topic/1582206-first-plex-already-made-mistakes/
Look for an LSI 9300-16i HBA. They are much easier to identify and purchase reliably. The 9300-8i is way too common with way too many manufacturers. And then you purchase mini SAS to SAS adapters to connect the HBA to the drives. I'll provide a link that connects to the 16i.
Depending on the drives, your PSU might not be able to power them if the drives have power disable "features." You will have to pull the 3v cord out of your PSU wires to make the drives spin. If you provide the make and models, we can provide more assistance (make and model of the 8TB drives and the PSU).
Adapter:
https://www.amazon.com/AdcAudx-Mini-SAS-Cable-Connector/dp/B09ZLGHZ5S
Where are you seeing 8 gig? Generally HDDs are pretty slow, so any semi recent HBA/RAID card would be more than enough to take full advantage of your drive.
Do you want software/hardware RAID? Thats the big factor if you should get a HBA/RAID card.
The 8 gig was from the interface pci 2.0 I think may be 3.0, I would like to make plex streaming as smooth as possible, which would be better software or hardware, and if hardware, what kind of raid card would you recommend, I read a few reviews on raid cards, they say they are compatible with sas, but then don't talk about them in the rest of the article
What software are you using?  Many NAS oses are built around software raid, so you really want to use a HBA.
Whats the rest of the hardware?
The PCIe speed won't matter, any of those x8 slots is way faster than your drives.
Using a i5 9th gen, 16 gig of ram ddr4 i think, gtx 1070 512 m.2 for boot drive (not sure if I can use it for page file on a raid system), for software I'm honestly not sure, something easy to use, most likely I will wait for that new NAS software linus was talking about (think he invested in it) it sound like it will remove most of the hard parts of making a plex (sorry can remember it's name)
Adapter:
Looks good, so just put sata power cable into the back of the adapter and plug in the drives with the otherside then pull in the other end into the card?
I am at 2.44GB used out of 4GB (I use 2x4GB drives for simple mirroring, as movies/TV shows aren't serious data for me) for 578 Movies (720/1080p) and over 1000 TV Show episodes.
Realistically, how much media are you looking to put on this Plex?  Ripping takes time to do, and downloading can eat your ISP limits and still takes time.
I usually grab things someone in my house wants to see that I can't get on Netflix/Amazon/etc.
It's fun at first, but it can be a time sink if you want to get ALL those Star Trek episodes for EVERY damn series. 🙂
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Sure you can, raid doesn't affect what drives you can use for a page file/swap drive.
Thats basically TrueNAS, so ZFS and you want a HBA for that. I'd get the HBA here then.
Yes, it is that easy. But it does depend on the drives you purchased. If they have power disable, then you will have to figure out how to disable the 3v wire coming from your power supply.
SAS drives are meant for data centers, and pushing a 3v signal to a newer drive actually prevents the drive from spinning. They do this to lower the power surge when they turn on a server. They start the main components, and then turn off the 3v signal, at which point the drives begin to spin and operate normally. It is totally backwards, but that's how it operates to balance the power load. I purchased a data center grade SATA drive and I had to separately purchase a pin extraction tool to remove the 3v pin from the PSU connector. Luckily I am using a modular PSU in my server/nas, and so I was able to do this. I can just plug it back in and use it again if necessary in the future. It just dangles in the case. I'm not sure to what extent you will need to do this. The extraction tool was like $10. I can send you a link if you need it. The major problem is if you are using a non-modular cable for your SATA power, then you may have to completely snip the 3v wire at the connector. It's not that difficult if you are electrically inclined. See the photo.
And to address another point that was discussed........ I'm not sure why hardware RAID was mentioned. It is nearly dead for consumer uses and it is another component that can go bad and destroy your pool and/or data. An HBA with software RAID is the way to go. If the HBA fails, you just replace it and reconnect your drives to the new one, and the software should do the rest to get your pool running again.
I worked at a movie store for 16 years, I have way way to many blurays and dvds, mostly will be only streaming to 1 or 2 devices, over wifi 6, and cat 5
Many many thanks, especially about the power being disabled, probably save me a month of trouble shooting
