Budget (including currency): $1100 AUD build
Country: Australia
Games, programs or workloads that it will be used for: Minecraft, cs2 valorant spiderman miles morales
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 180hz a i need an 8 core cpu and wifi
https://linustechtips.com/topic/1579398-pc-build-help/
Country: Australia
Is it just for the PC or do you need monitor and peripherals too?
Why do you need 8 core CPU?
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492042
10 minutes ago, Sychicyuto said:
just for the pc acctually 6 core good enough
a modern 6 core CPU is just as fast as an 8 core in gaming, going 6 cores might save you some money towards a faster graphics card that matter more.
Maybe something like this.
The motherboard has WIFI as you requested.
https://au.pcpartpicker.com/list/4HqDt7
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492047
oh jesus you sent one within my budget lol i made a previous post with 1200 dollar my acctually budget and someone sent me a build costing 1300 bucks So i thought if i choose 1100 someone will send me 1200 that didn't work lol
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492052
Well, there is no point in me sending a 1200 budget system if you list your budget at 1100 😄
If you have a 1200 budget I can improve on the build a little.
Basically the same build but with a faster GPU.
https://au.pcpartpicker.com/list/PVbWHG
You can of course pick a case you like more, its just a placeholder 🙂
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492066
last time i made a post I got sent a build 100 dollars above my budget i don't know about you but i don't have a  100 dollars lying around
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492617
Fortunately I do but I'v been in a position where I had to budget.
I sent you a good PC list for 1100 and 1200 dollars 🙂
I always stick to the budget people list.  No point in sending a list that over budget...  Or under budget as this would hinder performance too.
Right on point with the best parts 🙂
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492620
Yeah thanks man appreciate it
https://linustechtips.com/topic/1579398-pc-build-help/#findComment-16492901
