Budget (including currency):
Country: 500-550 usd (US)
Games, programs or workloads that it will be used for: Valorant, other rastuerized ganes
Other details :
i know the psu is a bomb, but a 250w safety space should (should) keep it ok
5600gt because of light editing and streaming. It’s only 9% slower than 5600, so I think it’s an ok tradeoff
Wifi functionality is a must
byikding for a friend, so I’d rather it be easy to build in and look clean (not a necessity)
Thanks 🙂
https://pcpartpicker.com/list/pBqnz6
https://linustechtips.com/topic/1576077-help-with-build/
Other details :
Thanks 🙂
PLEASE just get a new PSU, ebay would be better then that bomb, thats all
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461806
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($129.00 @ Amazon)
Motherboard: Gigabyte B450M DS3H WIFI Micro ATX AM4 Motherboard  ($69.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($29.96 @ Amazon)
Storage: Silicon Power A60 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Newegg Sellers)
Video Card: Gigabyte GAMING OC Radeon RX 6600 XT 8 GB Video Card  ($180.00)
Case: DIYPC F2 MicroATX Mini Tower Case  ($37.96 @ Newegg)
Power Supply: MSI MAG A550BN 550 W 80+ Bronze Certified ATX Power Supply  ($49.99 @ MSI)
Total: $551.89
Generated by PCPartPicker 2024-07-09 14:12 EDT-0400
You can buy more than just a GPU on the used market by the way.
Also I'm not sure the tradeoff for "light" video editing is worth the theoretical performance loss in the actual CPU.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461813
Total: $551.89
I get the l3s cut down, but the gpu it’s paired with should be enough to hold it down (lul)
Whats the better gpu on the used market? The Rx 6600xt on used market (where I am) seems to hang abt 170-180$, tho it kinda varies from day to day
ill consider the switch for the cpu, but it only seems to drop about 5-9% in average. I’m fine sacrificing a bit for cpu horsepower, but if prices switch I’ll change it
Also long time no see m8 🫡
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461825
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461828
nope the halfed cache can sometimes gut the overall power of the PC,
2 minutes ago, Linuswasright said:
… green label. It’s cooked 🫡
https://forums.tomshardware.com/threads/corsair-cx-experiances.3232681/
(Scroll to third post)
just get A550BN
current PC:
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461845
just get A550BN
Does 5600gt change much
i get it’s essentially a more powerful 5600g, but idk. I’ll probably switch. Form what I’ve seen, and benchmarks, it seems like a 9% drop (which is eh)
budget man, budget. Id like to keep it up to 520$
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461849
It can be a lot worse in the 1% or 0.1% lows making the game a stutter fest.
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461854
it's almost the same CPU
you can find DDR4 RAM, Ryzen CPUs on used market too,
you can find a really cheap case maybe,
or like a 50$ and less, high quality used PSU too.
not really, but perhaps lower lows regardless on average
current PC:
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461857
Parroting why_me, not really
4XXXg, now don’t get me started on that though
I think you get this from when zen 1 (and cut down zen 2) did this iirc
might be wrong
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461860
or like a 50$ and less high quality used PSU too.
Is there a good place to find the used stayed besides eBay?
where I live it’s like I’m getting trolled cus the best thing is cl18 3200 & 5$ less
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461861
AliExpress for the CPU?
also what country?
current PC:
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461866
also what country?
USA 🦅🦅
theoretically Danmark during the deep winter months, but I’d rather have it soon rather than kater
I’ve used aliexpress for 7500f, but I’d rather avoid it. I’ll still check it
edit:
I might just wait for RyZen 9000
https://linustechtips.com/topic/1576077-help-with-build/#findComment-16461869
