i want to buy 7 noctua fan for my home pc i want to know only can i connect all of those fan to one fanhub and control them? another question is i must connect that fanhub pwm controller header to cpu fan header or cpu opt header or cha fan header?
my case is asus (ROG Hyperion GR701)
fan i want to buy today is:
1.noctua-nf-a14-industrialppc-3000-pwm  _ 4fan 3 for intake 1 for exhaust
2.noctua-nf-f12-industrialppc-2000-pwm  _ 3fan my aio (ROG RYUO III 360)
3.deepcool-fh-10 pwm fan controller
i'm not gaming on this pc i do heavy rendering/coding for my works and projects.
https://linustechtips.com/topic/1573000-replacing-my-fans/
Yea that should work fine here. I don't see an issue.
I'd note those 3000rpm fans won't be quiet, and I'd probably get all the same RPM for fans.
Also Don't expect a big cooling upgrade over the current fans you have.
https://linustechtips.com/topic/1573000-replacing-my-fans/#findComment-16433443
thanks for youre time and answering😆
current fan are dead after few years those are from coolermaster halo series 4 140mm and 3 120mm i upgrade full pc last year but no fan upgrade until today
also less rgb make me suffer less because of that p*ice of cra*p armory from asus.
so all connect to hub its ok but where connect that pwm header to cpu header or cha fan header? which one is the best header?
https://linustechtips.com/topic/1573000-replacing-my-fans/#findComment-16433444
so all connect to hub its ok but where connect that pwm header to cpu heaser or cha fan which one is the best header?
Makes sense to replace dead fnas.
Fan header likely won't matter. I'd do CPU header if nothing else is plugged into that pin as its nice to monitor the RPM and controlls the speed based of CPU temp.
https://linustechtips.com/topic/1573000-replacing-my-fans/#findComment-16433445
Yes, if you get a strong enough fan controller, not hub, with PSU power, connects to the mobo (via header or USB) OR has a remote control for control, and it provides enough watts per channel for even those iPPCs. If you get just a hub, you're liable to run into problems mixing those different fans because of the really different current demands.
To be clear, if you find a hub that can handle the .65A draw of each iPPC, and it has PSU power with mobo connection or an RC, it'll be fine.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1573000-replacing-my-fans/#findComment-16433454
I would rather go for T30s. Its a better fan.. unless you are space constrained.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1573000-replacing-my-fans/#findComment-16433469
