Hi, i just bought an used xbox 360....please dont judge me... and i wanna record what i am doing so i bought a capture card with hdmi input, hdmi output, mic in and audio in, usb 3.0.
i plugged the usb 3.0 to my usb 3.0 port on my pc, output hdmi to my other monitor using a vga adapter, and input hdmi to the console and yet i detect no screen in obs, why?
https://linustechtips.com/topic/1572648-how-capture-card/
21 minutes ago, skayqz said:
please dont judge
6 minutes ago, skayqz said:
sry sry
You don't have to apologize, we just need the name of the product you bought, and it might also help to add the laptop model
Can you see the output on the monitor? And, did you add the capture card as a source on obs?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430195
Im using a pc not a laptop...and also i cant see an extra output on obs so i cant add it
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430200
And also yes i do see my xbox screen on my monitor
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430202
If you can't see the capture card as a source in OBS, chances are it's not detected. Are you able to go to the manufacturer website and find drivers for this product?
That's good, that means the card and the VGA adapter are both working
Primary PC:
PSU tier list
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430264
There are no drivers
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430267
What is the brand name of the capture card
Primary PC:
PSU tier list
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430321
Is it really that hard to post a link to the product?
F@H
GPD Win 2
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430351
2 hours ago, skayqz said:
In the description there is one thing that looks like a product name, but first can you tell us what shows up in device manager when you plug it in?
Edit: it looks like this product might be a generic product rebranded by brands like "kgeamp" or "dcyfol" so one of these distributors might have a generic driver to download
Primary PC:
PSU tier list
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430482
I didnt check device manager so ill check it when im at my pc again
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430589
vga to hdmi thow capture dose not work...
you need an analog to digital convertor.
if your playing on the same monitor as the captur there will be too much lag... so you get passed the lag you need a good analog to digital...
Edited by thrasher_565
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430596
The adapter doesn't seem to be the problem, OP can't pull up the capture card in OBS which I think would be a problem if the monitor was HDMI as well
Primary PC:
PSU tier list
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16430890
so you think they are not using a vga cable? there is a hdmi 360 but said nothing about it.
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16431075
They said they are and that xbox->VGA adapter->capture box->monitor chain works so it's not the problem. Just the capture box not being seen on the PC.
F@H
GPD Win 2
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16431083
vga to hdmi can work for monitor (sometimes) most times it flikers... but with out a analog convertor it wont work with captured i tried this...
all cheap convertors add inputlag.
i got a chaptur card and hooked my monitor that has vga and dvi to it with a dvi to hdmi adapter and thought that it would work...it didn't. so i thought the card was broken but found an hdmi monitor and it worked...
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16431089
Now i instead used an actual hdmi tv i had laying around, same issue.
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16431243
Are you trying to say that with the DVI adapter, you could see the video on the monitor even going through the capture card but your PC wouldn't see the capture card?
You keep mentioning input lag, but that's clearly not a problem in this case
Primary PC:
PSU tier list
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16431526
i can hook up pcs from hdmi gpu to hdmi to dvi monitor and it works fine but capture cards dont work they dont detect the signal. you can open up the program and seen a black screen and will say an error no signal.
this is what i got and got it as it said to work with w7 and well had to download older drivers to wack a mole error codes still never got it to work.
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16435455
Yep, it sounds like you are doing something completely different from OP so it makes no real difference here.
Also @skayqz if you post a screenshot of device manager we might be able to know more
Primary PC:
PSU tier list
https://linustechtips.com/topic/1572648-how-capture-card/#findComment-16435802
