display port Display port causes system to shutdown in some scenarios like gamming
After a long research due to problem persists in all ports, I've found a application called OCCT, used to stress tests for people that plays with overclock and etc.
During the stress tests I've noticed that the HOT SPOT (HS) was reaching 100º C or above, so after some point like 115º or 120º the the system shutdown to avoid permanent damage to the components.
In this video Jay-Z Two Cents have a issue where the thermal pads create a big volume of mass, when he put everything together, this volume creates a angle between the GPU processor and card metal plate, what causes a temperature increase.
In my case, the reference card uses thermal putty in the RAM, what gives a perfect contact between the RAM and the vapor chamber, GPU processor is also flat, when I replaced it with the thermal pad, it creates the same angle and also increase temperature, something I don't noticed when I put everything together, it can be trick even for experienced people like him.
After change the thermal paste to Thermal Grizzly Kryonaut Extreme and uses a thermal putty, 12.8 WMK like the old thermal pad, system has been repaired.
The delta temperature of the system (hot spot temp - gpu temp = delta) when I created the post, it would hit something like 40º C or above, now in Horizon Forbiden West in 4K with all settings in maximum in a open environment, the max peak was 15º C and usually 9º in closed environment or another games like Alone In The Dark 2024.
Some games, reach high HS temperatures pretty fast and some don't, by any reason, Dragons Dogma and Callisto Protocol, don't push the card to hard, so the system don't shutdown, same for Davinci Resolve, another titles like Alone In The Dark 2024 or the PS3 graphics indie game, does it.
By any weird reason, the first DP causes the system to crash faster than the second DP or HDMI, maybe just a nonsense coincidence, maybe not. I also found this video from Ancient Gameplays where he talks about a reddit post where some users report having problems with a bad DP cable, changethe bad cable for a good one, seems to improve overall temp, the video is not a test, so there is no technical answer, maybe a April's foll joke, maybe not.
Sorry my misunderstood about the situation and thanks fro trying to help.
